RPMs jumping
When im driving normally not gettin on it or anything, right around 45-55 before its going to shift my rpms start jumping back and forth and the exhaust starts making a sputtering noise. Is this something to do with my tranny or some kind of sensor?
Re: RPMs jumping
Sounds like basic misfire. Have you done a tune up such as spark plugs, wires, fuel filter, air filter, etc.? Do you ever get a SES light? Also try cleaning the MAF sensor. ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, TB spacer, MSD 8.5mm wires, Autolite 104 Spark Plugs, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
Yeah, I got new plugs about 3,000 miles ago but no new wires. Other than that no tune ups. How would I go about cleaning my MAF Sensor? Thanks for the help.
by the way its a 99 GTP
Re: RPMs jumping
It depends on your mileage but plug wires could be the problem and are cheaper than ignition coil packs or an ignition control module (ICN) which I'd think about next in the process. What brand spark plugs and type did you put in? You could get it odb-ii scanned and see what DTC error codes may pop up, if any. ![]() Thrasher CAI, DHP v1.0 PCM, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS, TB spacer, MSD 8.5mm wires, Autolite 104 Spark Plugs, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
