Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 07-03-2005, 08:48 AM
DB3893 DB3893 is offline
Question replace ignition 94 villager
can anyone please give a rundown how to replace the ignition switch on a 94 villager? we are hoping this will fix the problem. we turn it over and all the lights in the dash come on and you can hear clicking in the fuse panel under the hood and you can start it with a screw driver on selanoid so we are thinking the ignition switch is bad. Also we have checked all the fuses and they are okay. Thanks.
Old 07-05-2005, 05:48 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: replace ignition 93 villager
pretty simple, once you find it. its on the steering column close to brake pedal. disconnect battery, and then undo the 2 mounting screws and replace.
