Help Needed With 97 Sable Speedometer
What Would Cause A Speedometer And Radio Not To Work. Is There A Fuse I Can Change Or Something Else I Am Over Looking? Please I Need Some Help It Suck Driving With No Speedometer And Radio..
Re: Help Needed With 97 Sable Speedometer
Do you have a wiring diagram?
Is the radio getting power? Is the speedometer getting power? Are they grounded properly? Is there anything else not working? |
the radio and speedometer do work. while drive they work. after drive i turn the car off go to the store and come out the radio and speedometer both are not working. then the next day they are working again?? make any sence??
I had a similar problem with my 1997 sable. Have the windows also stoped working and does it happen in reverse and neutral to, if it does chekc your transmission range sensor. Or it could be your spedo sensor. But that wouldn't explain your window. I would go with the transmission range sensor.
Adam |
[quote=Graffiti_Dude]What Would Cause A Speedometer And Radio Not To Work. Is There A Fuse I Can Change Or Something Else I Am Over Looking? Please I Need Some Help It Suck Driving With No Speedometer And Radio..[/QUOTE) try and replace your speed sensor control cable sound like it going bad that should help you with your speedometer problem but for the radio cant help you there
