Go Back   Automotive Forums Car Chat > Cadillac > General Discussion
Old 07-02-2005, 10:04 PM
dragstercoffin dragstercoffin is offline
Need Help....1987 Fleetwood Brougham won't start
I have a 1987 fleetwood brougham that won't start. It cranks but won't catch. I've changed out the ignition module, distributor cap, ignition rotor, fuel filter and spark plugs. I put in a new alternator 6 months ago. Battery connections are good. Vacuum lines are good. I've tried everything. it acts like it's not getting any fuel. any help would be appreciated.
Old 07-03-2005, 02:38 PM
Antiburn's Avatar
Antiburn Antiburn is offline
Send a message via AIM to Antiburn
Re: Need Help....1987 Fleetwood Brougham won't start
DO you know if your fuel pump is working?
Old 08-06-2005, 07:56 AM
momissionary04 momissionary04 is offline
Send a message via AIM to momissionary04 Send a message via Yahoo to momissionary04
I had the same problem with my 1990 and didn't want to hassle with the repair myself. Huge mistake. I took it to the local Cadillac dealership, and after 3 new fuel pumps, a new fuel tank, and rebuilding the ditributor, at a cost of almost $5000, they determined that it was the fuel sending unit, that they may have damaged because of their numerous removals. I would sugget checking the fuel sending unit that's attached to the fuel pump. It will be a dealer only part, but you may be able to order one through CB Auto Parts in Neosho, Missouri.
