Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-02-2005, 09:49 PM
byerjv byerjv is offline
Fuel Filter 95 Camry
Does anyone know where the fuel filter is located on a 4 cyl 95 Camry? Is it easy to change? Thanks!
Old 07-02-2005, 10:37 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Fuel Filter 95 Camry
It is bolted to the wheel well behind the air filter housing. It is easy to change if you have small hands.
Before you disconnect any fuel lines, go under the rear seat - access the top of the gas tank, and disconnect the fuel pump electrical connection. Start the engine and let it idle until it dies, then shut off the ignition switch. Disconnect the negative battery terminal. Then follow the diagram below.
The fuel filter is removed physically by unbolting from the fender.
Use a tubing wrench (crows foot) instead of either an open-end wrench or adjustable jaw wrench to remove tubing connections. Use penetrating oil on the fitting first tp help remove it. They are soft metal and easily rounded off if you are not careful. Instead of a crows foot, a box-end wrench with a slot cut out of one end will work in a pinch.
Be careful not to twist the tubing when tightening or loosening a tubing fitting.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
