Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '88 - '91 Civic | CRX | Wagon | Shuttlee
Old 07-02-2005, 09:47 PM   #1
MaXXuS
MaXXuS's Avatar
F**K! Forgot where the hose goes!?
Okay, I just finished my head swap a little bit ago, and I can't get the car to turn over. Then I realise that I fucking forgot to plug the (I think) PCV hose in, where the hell does it go? Just in case, I am talking about the MIDDLE / | \ hose on the throttle body. It goes down underneath the throttle body, but what does it plug into. Its making me nutso, please help. Thanks.
MaXXuS is offline   Reply With Quote
Old 07-02-2005, 11:38 PM   #2
MaXXuS
MaXXuS's Avatar
hondacrx881.tripod.com/mpfiswap.html
The 2nd hose in the middle the thickest one, thats the one, where the hell does it go?
Old 07-02-2005, 11:50 PM   #3
livinincalifornia
Send a message via AIM to livinincalifornia
Re: F**K! Forgot where the hose goes!?
dual point? it's PCV if so, and it slides over an open ended pipe coming from the block
livinincalifornia is offline   Reply With Quote
Old 07-03-2005, 12:11 AM   #4
MaXXuS
MaXXuS's Avatar
Re: Re: F**K! Forgot where the hose goes!?
MPFI, exactly like in the pic above.
Old 07-03-2005, 04:39 AM   #5
MaXXuS
MaXXuS's Avatar
Could someone please lead me to some daigrams of the Throttle body install/repair pictures.
Old 07-03-2005, 04:17 PM   #6
Hybrid1990crx
Hybrid1990crx's Avatar
you car wont turn over at all? that one hose isn't going to stop it from turning over. are you sure you have power going to the starter? or do you mean it just wont start?
Hybrid1990crx is offline   Reply With Quote
Old 07-04-2005, 12:14 AM   #7
MaXXuS
MaXXuS's Avatar
Yeah it wasnt the hose, found where that went. The spark plugs/wires aren't firing off. The car sounds like it should be firing, but nothing happens. It sounds like it would turn over if the plugs would ignite, but the plugs also have a tiny bit of gas on them.
Old 07-04-2005, 01:15 AM   #8
johnb16a2
johnb16a2's Avatar
Check the rotor. A common problem is the rotor screw falls out. GL
johnb16a2 is offline   Reply With Quote
Old 07-04-2005, 06:40 PM   #9
MaXXuS
MaXXuS's Avatar
Okay checked that, nothing wrong their. The timing sprocket moves along with the belt, but like I said everything seems to go accept for the spark, and the plugs have a tiny bit of gas on their tips. I have new plug wires, new plugs, so we can rules those out. Maybe it is something to do with the distributor? I have never encountered this problem before, I have been looking through my haynes manual and nothing has caught my eye. If anyone else can think of something please post, thanks.
Old 07-05-2005, 09:25 AM   #10
johnb16a2
johnb16a2's Avatar
I had problems with my dizzy too, I fiddled with the ignitor, coil, etc. Just when I thought I had the problem solved it would die again. I eventually found a good looking dizzy on the junkyard and it solved the problem. The problem must have been one of the other sensors in the dizzy.
