Old 07-02-2005, 07:53 PM
drdd's Avatar
drdd drdd is offline
P0420, 0175, 0172 - cleaned MAF, running great, any ideas?
Well I'm getting codes for bad cat and bad o2 sensors (P0420, P0175, P0172). However, the truck is running great. No rattling cat, no rotten egg smell, no excess fuel smell.
I've cleaned the MAF twice. In the last 6 months: new plugs, wire, cap, rotor, pcv, checked MAP and IAT, cleaned TB.
I got a 97 Jimmy 4.3 with 117000 miles so warranty isn't an option on the cat.
I read a post about the PCM reading too narrow a range. Is this something that dealerships will reprogram for free? like a recall?
any ideas? I'm still reluctant to just go out and buy a new cat and 02 sensors with the vehicle running so well. Any harm in waiting?
Old 07-03-2005, 04:22 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: P0420, 0175, 0172 - cleaned MAF, running great, any ideas?
Just because it isn't rattling doesn't mean it is not bad.
Also, those codes are not for the O2 sensors, they are doing their jobs fine.
Seeing you have cleaned the MAF, how do you clean it?
Did the problems and codes come after you cleaned it?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-03-2005, 05:32 PM
drdd's Avatar
Re: Re: P0420, 0175, 0172 - cleaned MAF, running great, any ideas?
Codes were there before cleaning MAF. I thought cleaning MAF would do the trick. First time I cleaned it, I just sprayed TB cleaner onto the sides and onto the filiment-type wires and just wiped the sides with a rag. Still got the codes a day-or-two later. The second time, I sprayed and rubbed fairly delicately with my finger in a rag.
I should mention that it never looked dirty or sooty in the first place.
maybe i'm just not wanting to believe its the cat ... ??
Old 07-03-2005, 05:46 PM
drdd's Avatar
oh yeah ... also, after cleaning the MAF, I always reset the computer by disconnecting the battery for 15 min or so ... codes still came back ...
I'm also hearing a faint "meow" sound ...
Old 07-03-2005, 10:57 PM
BlazerLT's Avatar
AF -Advisor
A bad MAF can cause the problems you are seeing.
Also could be the CAT causing the last O2 sensor to put the engine in limp home mode which would cause the rich condition.
I would first replace the MAF, it has been know to fix all your problems before with another guy I helped over the phone.
Old 07-03-2005, 11:23 PM
drdd's Avatar
any way for a shade-tree mechanic to check the MAF ?
Old 07-04-2005, 12:34 AM
BlazerLT's Avatar
AF -Advisor
No unless you have a Tech2 computer to monitor its readings.
Old 07-09-2005, 09:01 PM
drdd's Avatar
Okay, my 97 Jimmy W is still getting the running rich codes in both banks.
I've done full tune-up, clean MAF, swapped with an Ebay 2001 MAF, replaced cat converter today. Still get codes.
The only thing I haven't done is replaced O2 sensors. I'm beginning to think I have a injector leak and that it is running rich and the 02 sensors are doing their job. That would explain the codes and the bad cat.
I don't smell gas inside the truck or under the hood. The truck seems to run great. Unfortunately I haven't kept great records of the gas mileage.
Other ideas ? Any ways to check for injector leaking? I think I have Central Sequential Electronic Fuel Injection ... will I need to replace all 6 injectors?
Old 07-09-2005, 11:53 PM
drdd's Avatar
Re: Re: Re: P0420, 0175, 0172 - cleaned MAF, running great, any ideas?
MAP sensor ?? anybody? ideas?
(what a loser ... replying to my own post !) haha !
Old 07-10-2005, 01:28 AM
BlazerLT's Avatar
AF -Advisor
Are you resetting the computer each time you do this?
Old 07-10-2005, 08:22 AM
drdd's Avatar
Yes everytime except ...
yesterday after I had the new cat put on. I asked the guy at Midas if they typically reset the computer after installing a cat. He said no. When I recieved the truck from Midas with my new cat, the SES light was off. It came back on in about 10 miles.
I'll try resetting ...
Old 07-10-2005, 08:31 AM
drdd's Avatar
oh I forgot ... I had the codes read at Advance Auto after the new cat install and after the SES light came on.
Their code reader resets the computer after reading the codes. So ... the computer is already reset, I'll just keep an eye on it ...
Old 07-10-2005, 12:02 PM
BlazerLT's Avatar
AF -Advisor
I don't know if a 2000 MAF will work on a 1997.
I suggest getting a MAF from Advance AP and trying it out.
Old 07-10-2005, 12:34 PM
blazee's Avatar
blazee blazee is offline
Problem?
MAF is the same 96 - present. AC Delco part # 213352
The code scanner clears the code, it doesn't reset the computer.
Old 07-10-2005, 01:42 PM
BlazerLT's Avatar
AF -Advisor
kew, just making sure.
