Old 07-02-2005, 07:22 PM
mitchdakid mitchdakid is offline
Leak In The Cat.
Not so much a blazer question but hopefully someone can help. I just replaced the cat on my 96, and now it sounds like there is a leak there. I got under and it sounds like it is coming from the front of the cat where it connects to the pipe, but when I felt around I could not feel any air coming from the cat. So I am wondering if it might be a bunch of smal leaks, or is it just how the new cat sounds. Any help would be appreciated. Thanks
1967 mustang coupe
new candy apple red paint with charcle striping, 351 windsor rebuilt 100 miles ago, 463 butt gears, B&M QUICK SHIFT, c-4 Transmission, shaved door handles, custom interior - not finished yet, 68 gt wheels-powder coated, slicks for the track, mustang 2 suspension.
1996 Blazer LS 2 door 4wd
aftermarket muffler-Flowmaster 40, cold air intake coming, blazer extreme body kit on it's way also, front has been lowered with tensioners, and rear with a block.
Old 07-02-2005, 10:58 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Leak In The Cat.
Did you disconnect any of the three-bolt plates that join some of the exhaust pipes together? Sometimes the bolts/nuts, and certainly never are the silver-metal looking gaskets between them are resuable. I had to replace a few of those gaskets, especially in the rear input pipe into the muffler when I re-did my pipework. And because I shook and juggled a lot of the stuff in front of the catalyst, had to replace the gaskets in the downtubes from the exhaust collectors too. It made this awful tickity-pop noises at idle and turned into a solid *SSSSSSSSHHHHHHHHH* when mashing on the gas. The only other thought that comes to mind is that if you purchased a "Universal fit" catalytic convertor, there is an air injection tube on one side. On my Blazer, such a tube would not be used because of the engine management and fuel injection with a complete lack of A.I.R. injection system to pump fresh O2 into the exhaust stream. However, if it came uncapped, it would also make the noise you are describing. Screwing a bolt into that small side tube will silence her right up.
Old 07-03-2005, 05:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Take it back to where you got it installed.
That is their problem.
It shouldn't leak at all.
1995 Factory Blazer Service Manual for sale, PM if interested.
