Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-02-2005, 05:23 PM
pimpcrx_kid pimpcrx_kid is offline
Send a message via AIM to pimpcrx_kid Send a message via Yahoo to pimpcrx_kid
bolt sequence
im sure its online sumwere but ive looked online for the past hour and a 1/2...im tryin to find the sequence of the cylinder head bolts im putting a d16z6 head on a d15b7 block in my 90 civic,if u can supply me with a picture that would be great..thanx ~marcus
Old 07-02-2005, 10:59 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: bolt sequence
as far as bolt sequences go...................i dont ever use the helms or haynes for that. i just start from the outside corners and work my way in. ive never had problems.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 07-02-2005, 11:58 PM
Re: Re: bolt sequence
dont u mean u start at the middle and work your way out?...u got me a lil bit confused..
Old 07-03-2005, 03:45 AM
AF - Advisor
Re: bolt sequence
i work from the outside in. starting from the mid out would be ok too. im more focused on the correct amount or more torque than sequences.
Old 07-03-2005, 11:18 AM
i found it its 22lbs step 1 and 53lbs step 2 n u go middle out,now how do i delete this thread?
Old 07-03-2005, 12:25 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: bolt sequence
I start from the inside and go out in a spiral pattern...and for the torque specs, i do 75% of the torque the first time and then i start back in the center and torque them all the way in the same spiral pattern as before.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 07-03-2005, 03:31 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: bolt sequence
Fuck that bullshit, go by Hondas specs...
8 6 2 4 10
9 3 1 5 7
and the torque amount is 22lbs-ft for the first step and then go back and do them 53 lbs-ft
You do it that way to insure even pressure across the mating surface, lessening the chance of leaking and warpage.
Old 07-03-2005, 07:55 PM
AF - Advisor
8 6 2 4 10
9 3 1 5 7
its the way to go.
but, ive never had problems with my technique
