Old 07-02-2005, 02:55 PM
stratpunkr stratpunkr is offline
ZC not sparking
I just got ready to fire my zc up and i have no spark at all. Im pretty sure all the grounds are hooked up, batterys good, although i did have to switch the cap from my old engine (d15) because the one that came on the Zc was cracked. Any ideas? DO i need a whole new dizzy?? or did i just forget something
Old 07-02-2005, 11:13 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: ZC not sparking
you checked to see if you had spark? the simple stuff needs checking first.
plugs
wires
rotors
cap
coil
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 07-02-2005, 11:17 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
did you switch wires around on connector to dizzy? if so then you got the peach and white 1 i believe backwards.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 07-03-2005, 11:35 AM
Sikocivic's Avatar
Sikocivic Sikocivic is offline
Re: ZC not sparking
There are 2 white wires in the dizzy harness. Try switching them around. I get that wrong every time.
90 Civic Si Turbo ZC
Old 07-07-2005, 01:45 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: ZC not sparking
yeah, those two white wires will always mess you up.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
