Old 07-02-2005, 01:49 PM
jhsmith246 jhsmith246 is offline
replace timing cover without removing oil pan?
I have a big gasket leak at timing cover but gm manual says remove exhaust pipes, starter, and oil pan to remove timing cover. is there a simpler way (tricks)? like drop pan a little without removing other stuff? this reminds me of egr pipe repair: step: 1 disconnect battery; step 2: remove engine...
Old 07-02-2005, 01:52 PM
I forgot: its a 94 LT1 in a camaro z28. sorry about that.
Old 07-02-2005, 01:54 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: replace timing cover without removing oil pan?
why not just clean the oil off, get some high temp gasket seal and put it around the leak? I got a tiny leak in the same spot.... I'm just going to try to pack gasket seal into it.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-02-2005, 02:01 PM
that might be the only way--problem is I cant tell exactly where on cover the leak is since it has thrown oil all around there.
Old 07-02-2005, 02:05 PM
just clean it all up... then run the car for 5 mins, then look where it's coming from. or just seal around the entire bottom section.
Old 07-02-2005, 02:08 PM
thanks, will try that.
Old 07-02-2005, 08:59 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
chances are its from around the crank seal, gotta do it by the book if thats the problem im afraid.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
