Old 07-02-2005, 01:23 PM
yehaw yehaw is offline
hesitating and stalling
'93 Grand Am, my daughters car has a hesitation and sometimes stalls from take off and or stops. I have changed plugs, oxygen sensor, and put several cans of Sea Foam into her gas tank. I recently had it at my local garage for a brake inspection, ABS light came on a couple of times when my daughter was driving.... she also said that she felt soft brakes a couple of times. The garage put it on the dig. computer and found nothing wrong. They installed a new fuel filter and that did not cure anything either. Any ideas..... Thanks yehaw
Old 07-03-2005, 01:29 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: hesitating and stalling
Try tapping on the MAF while it idles. Use a screwdriver handle, or rubber mallet, something that won't crack the plastic. If the idle reacts by stumbling, misfire, or whatever, the MAF is bad.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
