Old 07-02-2005, 01:11 AM
dieseldoc dieseldoc is offline
Tire and wheel clearance
Ok, I got offered a real nice set of new tires from a friend for dirt cheap. Their 225/60/16's Bridgestone potenza's. The only thing is I'm not sure if they'll clear the struts on the front. Anyone know??? Thanks. 1994 Base model.
Old 07-02-2005, 01:16 AM
Hotshot8792 Hotshot8792 is offline
Re: Tire and wheel clearance
Originally Posted by dieseldoc
Ok, I got offered a real nice set of new tires from a friend for dirt cheap. Their 225/55/16's Bridgestone potenza's. The only thing is I'm not sure if they'll clear the struts on the front. Anyone know??? Thanks. 1994 Base model.
thats the stock tire size for the base models, they will work just fine
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-02-2005, 02:13 AM
Wischmaster's Avatar
Wischmaster Wischmaster is offline
Thank goodness they are 55's. These cars would look dumb with lo-pro tires on 16's. I could fit my Civic in that wheel gap then.
Old 07-02-2005, 03:07 AM
Sorry 55's are what's on there now, i ment 60's there a good bit bigger.
Old 07-02-2005, 10:15 AM
Re: Re: Tire and wheel clearance
They would probably clear, but they would throw your speedometer and your mileage recording way off. If you want 16s, try to stick with either 225/55/16s or 245/50/16s
Old 07-02-2005, 02:28 PM
Thanks Hotshot and Wishmaster for your reply's. I went to Wal-Mart and had a friend mount a 225/60/16 on my front rim and it won't fit. The spring pad is to low for proper clearance. Thanks again guys.
Old 07-20-2015, 04:30 PM
hollydolly hollydolly is offline
whats stock size on my 1995 3000gt sl. Next what size looks the best on my model?
Old 07-20-2015, 10:39 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Stock size for a SL is 225/55/16. You could run 245/50/16 for a wider stance.
If you have 17" rims you would run 245/45/17.
