Old 07-02-2005, 12:16 AM
Metrokid Metrokid is offline
engine swapping
i have two geo metros that i would like to swap engines in. one is a 93 geo metro and the other is a 97 geo metro. the engine in the 97 froze up so i want to put the 93 engine in it. is this possible? the information to the 93 is VIN: 2C1MS24X6P6735573 1.0 L 3 Cyl. and the information for the 97 is VIN:2C1MR2265V6720278 1.0 L 3 Cyl. Thank You for your help in advance.
MetroKid
Old 07-02-2005, 07:40 AM
Tominator2000 Tominator2000 is offline
The only dif is that the '97 requires a crank position sensor. The holder is part of the block, so no you cannot use the earlier motors.
Old 07-02-2005, 07:50 AM
lumpylowell lumpylowell is offline
Send a message via Yahoo to lumpylowell
computer
maybe he could use the harness and computer form the '93, but only with a wiring diagram from both cars
Old 07-03-2005, 10:18 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: engine swapping
you can swap it over but you have to change the entire front of the motor, the intake and exhaust. on the front of the motor the oil pump is different, the 97 has the crank angle sensor and so is the cover and cam gear. if old motor is froxe up oil pump may be bad too. rather than changing everything and puying a new pump look around for a 96 or newer motor, not to hard to come by usually
Old 07-04-2005, 11:50 AM
Re: engine swapping
thanks for the information. do you know where you could get a tool to center the clutch and clutch disc?
MetroKid
