Old 07-01-2005, 11:53 PM
RG501 RG501 is offline
Send a message via AIM to RG501
Looking for a AMP
I've been looking around for good sub to put in my firebird. people have suggested the RE series and i think they would be a good choice. i want to put 2 RE 10's in a box. each sub is:
10"
175 RMS watts
dual 4 ohm
now i need a amp to power the subs. i need some recommendations that would fit the specs of the subs. as far as budget, i was looking around at profile amps. i saw that they're around 60$-80$. so anything around there is good.
thanks.
1996 v6 Pontiac Firebird
Old 07-07-2005, 12:41 PM
Re: Looking for a AMP
anybody have any suggestions?
Old 07-07-2005, 03:27 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Profile AP1000 would work just fine...
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 07-07-2005, 11:13 PM
the amp says its 160 rms watts at 4 ohms and 240rms at 2 ohm. how do i get it hooked up at 4 ohm?
Old 07-08-2005, 11:31 AM
highteknology's Avatar
highteknology highteknology is offline
Send a message via AIM to highteknology Send a message via MSN to highteknology
here's how you'll wire it to 4ohm
http://www.rockfordfosgate.com/rftec...x=21&image.y=6
the only problem i see right now, is that you may want more power than just the 160 watts for both subs.
Old 07-08-2005, 12:39 PM
well, each sub can only handle 175watts rms. so i dont wanna go over that. right?
Old 07-08-2005, 12:45 PM
right, but what i'm saying is that one of the amps you are looking at is only going to put out 160 watts. the wiring diagram up there shows two woofers hooked up. so, the amp would theoretically be pshing 160 watts for two subs, or like 80 watts a sub. im pretty youd want a little more
Old 07-08-2005, 01:55 PM
well, the amp is a 2 channel amp that has 160 watts PER channel. so its like each sub is getting 160 watts.
should i get a amp that puts out about 200 watts per channel?
Old 07-08-2005, 04:57 PM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
i jsut did a dual RE12 install using an Hifonics NX400, 200WRMS per channel, 2ohm. and it sounds pretyt awesome. and the RE's can tale 250W, but not for extend periods of time. and keep in mind that you only get 160W when its @ full volume, so make sure your speakers and handle full volume.
Old 07-09-2005, 07:38 PM
i found a profile AP 1200 that puts out 200rms watts at 4ohm. so would this be a good amp to get?
Old 07-09-2005, 11:33 PM
fred495us1 fred495us1 is offline
If each sub can handle 175 watts RMS you would want an amp that puts out about 350 watts RMS.
Here are your options.
1. get a mono sub amp that puts out about 350 watts RMS at either 2 or 4 Ohms. Use wiring option #1 from the link above for a 2 Ohm load or Wiring option #2 from the link above for a 4 Ohm load. Mono amps are usually stable in both 2 and 4 Ohms.
2. get a 2 channel amp that can be bridged and is 4 ohm stable and puts out about 350 watts RMS in bridged mode. Use wiring option #2 from the link above.
Usually, an amp is bridged by connecting the speaker leads to the positive (+) terminal from one channel and the negative (-) terminal from the other channel
Old 07-10-2005, 12:06 AM
profile HA600 = 300 rms watts bridged (4ohm)
hows that amp?
Old 07-10-2005, 11:13 AM
icecursor icecursor is offline
Re: Re: Looking for a AMP
I'm installing two 10" subs and I bought them at ebay for about $50 brand spanking new. I also got an 800W kenwood amp for $80.
Old 07-10-2005, 03:20 PM
what kind of subs are they?
Old 07-10-2005, 05:01 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
profile is over rated, so is hifonics but for your situation id look at Hifonics NX400. its rated at 200w RMS x 2 @2ohm. so wire each subs coils in parallel and then each sub to a chanel.
it'll wand decently hard. RE's are good budget subs.
