Mysterious front-end clunk
I own a '92 S13 with 118K miles that has developed a mysterious clunk whenever I turn into a driveway, or on an incline on the street. I don't feel any vibration through the steering wheel, so I don't thinks it's steering related. Today I pulled the front-end apart looking for the source of this noise. The lower-control arm ball-joints seem to be tight, as well as the tie rod ends... The struts seem to be alright, upper bearings are not loose. I have checked everthing, and have come up with nothing. Has anyone come across the same problem, and found the solution? Please post anything that might help. Thanks in advance for your help.
Re: Mysterious front-end clunk
A clunk is a worn bushing.
do you have aftermarket springs? sometimes if they are not fit right they won't seat nicely into your struts... the turning could cause it to shift around...
but then of course it's most likely cracked bushing... like what slidestar said.
1993 RMS13 5MT KA |
I have a 92 FB and i have the same prob annoys the hell out fo me can't find what bushing it is, i think its my engine or tranny mounts
![]() Check out my Car Domain: http://www.cardomain.com/ride/718525 |
Re: Re: Mysterious front-end clunk
bingo?
1993 RMS13 5MT KA |
Thanks for your help. Am going to replace all bushings with energy suspension master bushing set. Will post the results soon.
i'm thinking about getting a set as well... installation is gonna be a b---h
1993 RMS13 5MT KA |
I have the exact same problem. Is it more of a clicking/grinding noise? I can't figure it out. My bushings look fine. Maybe I will just get a bushing kit to be sure
I have the same problem. Notice it mainly when backing up and turning wheel? It's the bearing for the upper strut mount... Can't find the site right now that sells just the bearing, but it'd prob be good to go ahead and replace the whole strut mount.
I replaced TR bushings, ball joints, before I finally found that damn bearing busted...... Edit: Found it!! PDM Racing Text: Quote:
thanks lost, it was exactly that problem. It got to a point where I would hit bumps and my bearings would make that noise. Well, i ordered new uppermounts from D2. Is there anyway to prevent it from happening again? My current D2s were pretty new... Grease up the bearings this time?
Dont replace your front tension Rod Bushing with that crap. It will cause your Tension Rod Bracket to crack eventually because it wont let the tension rods Rotate Freely. Heim Joint or Stock is the only way to go for tension Rods. |
