Old 07-01-2005, 10:43 PM
thepaivaVR-4 thepaivaVR-4 is offline
Question stealth/3000gt?
i would like to know who is faster between the vr-4 and the tt stealth
or are they the same. i always thought they were the same because of the same engine and everything but some people said that the stealth is faster because it was lighter. so which one is lighter?
Old 07-02-2005, 12:35 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: stealth/3000gt?
The Stealth is lighter. It should be about 1 to 2 tenths faster if that.
Old 07-02-2005, 01:14 AM
Hotshot8792 Hotshot8792 is offline
right, everything inside and outside about both cars are 100% the same, except for a couple of body parts, which are, in fact, directly interchangable between cars except for the spoilers. The stealth tends to have a few less options making it a lighter car.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-02-2005, 02:10 AM
Wischmaster's Avatar
Wischmaster Wischmaster is offline
And I believe the 3000's for the first gen's are a whole 1" 1/4in shorter in length. But they are heavier... bleh.
I still wuv mine!
Old 07-02-2005, 01:21 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Re: stealth/3000gt?
stealth is light due to the fact that the 3000gt came with all the active aero stuff. that front venture plate in the front of the 1st gen and some of the 2nd gen 3000gts weight over 100 lbs... but ultimately there is not much dif between the 2... not enough to tell if one is faster than the other... mabey the stealth would cross the finish line a inch in front of the 3000gt.
Upgrades... To many to list...
Old 07-02-2005, 01:22 PM
92VR4Red's Avatar
Re: stealth/3000gt?
i take that back none of the 2nd gens came with the front venture plate... my bad. but the 1st gens did
Old 07-02-2005, 08:13 PM
Knight2040's Avatar
Knight2040 Knight2040 is offline
Send a message via AIM to Knight2040
Re: Re: stealth/3000gt?
sorry to be slightly off-topic..but whats a venture plate?
1991 Mitsubishi 3000GT VR4 Twin Turbo- Forged Ross Pistons,Forged Crank,Forged and Shotpeened Rods,Stillin DP,K&N FIPK,Greddy Type-RS BOV,Magnacor Wires,Aluminum Y-Pipe,EGR Blocked,All Gutted Cats,Greddy Turbo Timer,Blitz Boost Guage,Autometer A\F Guage,Solid Shift Bushings,Red Top Batt,ACT 6 Puck Clutch,Free Boost Mod,99 Front End Conversion
Old 07-02-2005, 08:19 PM
92VR4Red's Avatar
Re: stealth/3000gt?
on 91-93 models there is a front spoiler... mitsu calls it the front venture plate... its the big black cover underneath the front bumper and engine, that goes up and down when you turn on active arrow... it moves both the wing and the venture plate... it has 2 moters and is renforced with metal brakets plus its made up of polyurthane... so it is pretty heavy...
Old 07-02-2005, 09:15 PM
Knight2040's Avatar
oh..dude i had one but i took it off cuz it broke..but the big black spoiler was real light..maybe like 9lbs at most...i too the motor and rod thing out wit it and misic brackets and they were pretty light too...maybe i missed more...lol idk
Old 07-02-2005, 09:44 PM
92VR4Red's Avatar
Re: stealth/3000gt?
idk either... this is what i was told... i never fooled with mine... its still on.
Old 07-03-2005, 12:35 PM
Igovert500's Avatar
blue + red light magnet
Re: stealth/3000gt?
My 96 had one as well, but I took it off/curb ripped half of it off.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-04-2005, 02:39 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: stealth/3000gt?
mine is getting bad also
Old 07-04-2005, 09:01 PM
duchguy's Avatar
duchguy duchguy is offline
Send a message via Yahoo to duchguy
Re: stealth/3000gt?
I had mine replaced
Old 07-05-2005, 12:32 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: stealth/3000gt?
venturi plate aka venturi skirt
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-09-2005, 07:49 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: stealth/3000gt?
the 2nd gens with AA, 94-96, had that also, but it is very light. With the brackets I would guess around 15 lbs tops.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
