Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-01-2005, 04:08 PM
atv087 atv087 is offline
Send a message via AIM to atv087 Send a message via Yahoo to atv087
this car is a piece of shit
i had my ac working great for 3 days and then today i started up my car and put the ac on and when i got back out to the car it was really hot inside it was blowing out hot so i took a look under the hood and the clutch for the ac wasnt cycling it was just staying engaged
and the compressor was ice cold what does this mean
Old 07-01-2005, 09:07 PM
Re: this car is a piece of shit
the big silver thing was cold* sorry i dont know the exact name for it do i need a new compressor or a new clutch or a new switch because i think the freeze12 i put in my system without vaccuming it out ruined something
Old 07-02-2005, 06:37 AM
auto trainy auto trainy is offline
From what you posted previously its sounds like you do have another problem which probably caused you compressor to stay on thus making your clutch to go.When ever I try to fix something I always say to myself can I fix this or am I guessing,maybey there was something there before the freeze 12.
Old 07-02-2005, 08:03 AM
well before this the ac diddnt run for a year and a half so id suppose the clutch had grime in it and it was just burning off but what should i replace the ac compressor or just the clutch
Old 07-03-2005, 10:46 AM
ok where ive gotten so far its either the compressor went bad due to the freeze 12 and just stays engaged when you turn the ac on for some odd reason. Or I have a leak and the freeze 12 did not kill my compressor and that i need to repair the leak before i put more freeze 12 into my system. I have a feeling that its not a leak. Any ideas where i should go from here?
Old 07-27-2005, 01:42 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
try to check the fuses or relays for the AC compresser/clutch, happened to me before, was just a burnt fuse, and it worked, and i did retrofit my system too after that. but give the fuses and relays a once over just to check
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
