| Off-Topic Talk about anything other than cars. |
I heard that the 2000- years of Eclipse's had a Dodge neon Engine in them. My opinion, Neon are garbage. Do the 2000+ eclipse's have different engines in them? <-----hopefully not the neon engines.
Re: Dodge Neon Engine???
the rs and gs had neon engines in them. the gst and gsx didn't. NO the 2000+ have a 4g64 that came in the 95 spyder gs and the gt and gts have a v6 similar to that of the 3kgt
MODS , 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo and the ac still doesn't work and its been almost 3 years |
This might help:
95-99 RS/GS Eclipse: 420A 95-99 Spyder N/T Eclipse: 4G64 (95-99?) Neon: 420A 95-99 GST/X Eclipse: 4G63 2000+ RS/GS Eclipse: 4G64 2000+ GT/GTS Eclipse: 3.0 Liter, not sure of engine code So no, the 2000+ RS/GS Eclipse does not have a neon motor. This probably would have been a better question for the guys over in the 2000+ Eclipse forum, but w/e.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Most people refer to the 420a as a neon motor, but this motor appeared in the eclipse before the neon. It's more like the neon has an eclipse engine. Also the 420a was only equiped in the high trim neon. I'm not 100% sure, but there never was a DOHC neon between '95 & '99, meaning it would have a SOHC 420a????
1993 Eagle Talon ES (4g63NA) 14.6 @ 98 mph (110 octane race fuel) -5 Speed Transmission (From a 4g67) -Stage 2 Crane cams -Ported and polished head -Aggresive valve springs -2.5" Custom made exhaust piping -Custom header -Gutted catalytic converter -Bored 0.5mm -Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC) -2g valve lifters (Lifter noise returned, now it a true DSM) -K&N w/modified air canister |
Re: Re: Dodge Neon Engine???
I also think that I read somewhere that it had either a 3 speed auto or a 5 speed manual. Why the hell would somebody want the 3 speed auto? That just another reason why the neon sucks dick compared to an eclipse.
I owned a 16V DOHC neon. It was the a 96 Plymouth Neon 5 speed sports coupe.. I know people shit on neons, but that was a fast ass car. It even had that little schoop on the hood the eclipses have.. except it was as big.
![]() ![]() 1998 RS 5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs. |
[/quote] That would be 6G72 it is a little different from the 3000GT motor because the 3000GT where DOHC and the GT/GTS are SOHC I think that the 3g Eclipses and the 2g Stratus Coupes have the same motors in them
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads. |
actually it is the same motor as the 3kgt. in the early years the n/t 3kgts came w/ a sohc 3.0 . true it is a little refreshed if you will but for all basic terms its the same motor.
1990 mitsu eclipse gsx 16g 550's burned eprom chip 2g mas 3" turbo back custom exhaust port&polished head, turbo, exhaust mani mml headgasket b.s. elimination centerforce df2 unorthodox crank pulley autometer boost , a/f hallman es mbc homemade fmic and piping relocated battery lower in engine compartment purty candy red valve cover stripped interior couple of random guages man this is a big list of nothing special......gotta work on that 50trim in the works |
Now there is no "Neon Motor" in any Eclipse. Sure there is a Chrysler 420a motor but its a lot different than a 420a motor in a Neon. For one, the head is different. Intake manifold is on the front and the exhaust manifold is on the rear. They also have different cams. They do however share the same block but the timing components are a little different. Just thought I would clear some things up. |
