Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-01-2005, 02:59 PM
Chirpn'3rd Chirpn'3rd is offline
Angry Running rich
OK!!! Here's what I got.........
1990 TSi, VR4 engine swap, 50 trim turbo, ported 1st gen exhaust amnifold, 2nd gen ported 02 housing, 2 1/2" exhaust from downpipe back(no cat), boostin 1.8BAR, Greddy typeR BOV(vented to atmosphere), front mount intercooler, 660cc injectors, 2nd Gen MAF sensor.
Here's the prob.................
This thing is running so rich, what can i do to still vent to atmosphere, but not runn like shit? Any and all help would be great!
!THANKS GUYS, AND GIRLS!
Old 07-01-2005, 03:28 PM
Re: Running rich
Help, I Need Help
1990 Tsi AWD ( DEAD )
2001 GOLF GTI ( LOVE IT! )
1986 300ZX ( TOO OLD )
Old 07-01-2005, 03:30 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: Running rich
gm maft and translator is what you are going to need. or just make sure you have a good connection on the 2g maf.
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 07-01-2005, 03:40 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Running rich
Venting will richen your shifts, but if the car is always too rich, it's because you have 660s and no tuning or logging whatsoever.
Old 07-01-2005, 05:47 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Running rich
32% too rich from the injectors, but another ~20% leaner because of the 2g MAS, strange combination. And 26 psi is way too much boost to be running while you have no way to tune the car properly, or even log to see if its knocking or not. Turn the boost down, and finish modding the car (tuning/logger).
Edit> If I sound a little short, it's because I'm offended when people bump their thread after only 29 minutes. Like we sit here all day
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-02-2005, 02:49 PM
Re: Running rich
Ok, Thanks Guys. I'm At 1.3 Right Now, Is That Still Too Much? My Buddy Told Me That If I Invest In An Safc I Can Take Care Of Some Of My Issues. Would I Still Need The Gm Maf And The Translator?
Old 07-02-2005, 05:27 PM
Re: Running rich
Yes sir, the 2g maf is still reading that you are getting more air than you are so it is going to run rich whenever you shift. This also depends on your car though. When i was venting the car ran the same way as it does now.
MODS
Old 07-02-2005, 07:47 PM
Re: Running rich
Ok, I'm Just Gonna Spend The $$$$$ And Do It Right Then. New Gm Maf, And Translator. With The Translator I Will Be Able To To Adjust The A/f Ratio, So Even If It Is Still Running A Bit Rich I Can Compensate For It. Thanks Much Everyone!!!!!
Old 07-02-2005, 10:59 PM
JoeWagon's Avatar
Banned
Re: Running rich
stop and think for 2 seconds. If you have larger than stock injectors, you need to compensate for them. MAFt isn't a great tuning device so you will need an S-AFC or better.
Old 07-03-2005, 12:21 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Running rich
you ran a 11.6 ET on that setup???
DSM geek
Old 07-03-2005, 08:38 AM
AF - Advisor
Re: Running rich
The newer versions of the MAFt have the capability to tune just as well as the AFC, but the AFC is MUCH easier to use...
Kevin Jewer
Old 07-05-2005, 04:03 PM
Re: Running rich
I've heard that the afc is easy to use as well. but I'm trying to keep the cost to a minimum if i can.
Old 07-05-2005, 10:34 PM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
Re: Re: Running rich
WWTTTFFFF soo does running rich make you lose power?!?? cause I am running rich!!!!
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
Old 07-06-2005, 08:26 AM
AF - Advisor
Re: Running rich
Depends on how rich. How do you know you are running rich? 11:1 is typically ideal on pump gas for us, but anything down to 10:1 will still make power. Stock AFR is 9.5:1 once you are over 2.1 g/rev.
Edit> In the case of the original post, the stock 9.5:1 would become 6.5:1 with 660s, but then the 2g MAS will bring it back out to around 8.2:1. That is rich enough to cause a serious loss of power. I would also be checking my compression. Excessive fuel can wash the oil off the cylinder and accelerate wear.
Kevin Jewer
