Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-01-2005, 01:42 PM
pimpcrx_kid pimpcrx_kid is offline
Send a message via AIM to pimpcrx_kid Send a message via Yahoo to pimpcrx_kid
how do i run vtec?
i got 90 civic dx with mpfi swap then i recently did a d16z6 head swap but i cant afford a $350.00 vtec controller right now and im using the si intake and distributor and ecu,so is there anything cheaper i could do too run the vtec? will the car be ok too drive around with the vtec not hooked up intill i can afford a controller? ive heard msd makes something like a vtec controller but i dunno if thats true...
thanx ~marcus
Old 07-01-2005, 02:53 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: how do i run vtec?
Si, meaning the P28?, either way...
http://www.hondaswap.com/forums/inde...0&#entry540217
Old 07-01-2005, 02:57 PM
Re: Re: how do i run vtec?
nah man si meaning pm6 umm 88-91 obd0 si's... hey did u get assigned to me youve been a big help i only ask cuz your the only one who answers my questions (thanx jcrx ) ~marcus
Old 07-01-2005, 03:06 PM
Re: Re: Re: how do i run vtec?
that is a pretty sik link you sent me however my car is obd0 not obd1..i dont have the obd1 conversion so im a lil confused on what too do
because my stock pm6 ecu doesnt come with vtec it is actaully the sohc mpfi non vtec ecu from 88-91 crx/civic si,i found a thing i think might work from summitracing.com the part # is MSD-8950,will this work?? i could set it to have vtec come on at like 5,200 rpm and then i guess it shuts off if the rpm's fall below *5,200* rpm n comes back on when it hits 5200 again? ( 5,200 using as a example )
Old 07-01-2005, 03:21 PM
You could do it via an rpm pill, but, if it were me, I'd get an OBD I vtec ECU, and a jumper harness, then run the wiring like in the link. Reason being is that vtec is controlled by the ECU and is activated under four conditions
1) vehicle speed, via the VSS (vehicle speed sensor)
2) Oil pressure
3) engine temperature
4) Engine speed
Hooking it up through a pill or switch bypasses these parameters, and can be bad for you motor.
Old 07-01-2005, 03:27 PM
2) Oil pressure
4) Engine speed
if i do that can i still run my si distributor and si intake (si meaning d16a6) and si injectors and resistor box...wont i have to switch all that suff over too obd1? or just the ecu???
Old 07-01-2005, 03:31 PM
Actually...I don't think you can use it all with an OBD I ECU Pretty sure the distributor will not work. Look around on that site I lniked you too, there's a lot of OBD 0 guys, and a great OBD 0 specific forum, someone there will have a good solution for ya.
Old 07-01-2005, 05:15 PM
k man thanx for everything ~
Old 07-01-2005, 05:53 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
This might help a little: http://hybrid2.honda-perf.org/tech/sohcvtec.html
Old 07-01-2005, 09:09 PM
Originally Posted by CivicSpoon
thanx dude youve helped out alot thats exactly what i needed to see!! thanx alot ~marcus
Old 07-02-2005, 01:03 AM
duffman868 duffman868 is offline
you cold also chip it with turboedit. i think they use the ac wire on the ecu to activate vtec. then you can run a vtec map so you dont run lean up top. or you could activate it with a rpm switch and run a vtec map
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 07-02-2005, 05:35 PM
how exactly would i do that and is there a website about "turboedit"?? i dont know much about vtecs i just got into them this year i know basic mechanics for 88-91 civics/crx's like i kno how ta change cams n engines but as far as chippin my ecu i dunno how ta do stuff like that although i really want to learn im just not at that level yet so if u can hook me up with info that would be cool
Old 07-04-2005, 10:09 PM
championWhite_R's Avatar
championWhite_R championWhite_R is offline
how do u know when da right time to activate vtec??lets say tat u hv a v-controller.. how to determine the timing for vtec?
Old 07-05-2005, 02:50 AM
go to www.pgmfi.org for chipping info
Old 07-05-2005, 03:06 AM
nice thanx
