Old 07-01-2005, 12:49 PM
Mango™'s Avatar
Mango™ Mango™ is offline
A/C keeps popping fuse
All the sudden the A/C keeps popping the fuse. The clutch turns, looks normal. It was working fine and all the sudden, pop.
Is the compressor out?
I have had problems like, a/c would work but if I turn it off the a/c would come back on hot, like the freon was out.
If the truck was cold the a/c would work.
I can get a compressor for $105.00 with exchange, should I replace it?
Do I need to flush the old freon out or can I just add new freon?
1991 s-10, v-6 4.3l 159k miles
Thanks
Old 07-11-2005, 12:00 PM
Mango™'s Avatar
Re: A/C keeps popping fuse
bump
Old 07-11-2005, 12:28 PM
rstroud rstroud is offline
Put a set of gauges on your system and check the pressures with engine/AC running. If the pressures are the same on both low/high sides, your compressor is shot.
Old 07-13-2005, 11:49 AM
Mango™'s Avatar
I can not turn on the AC the fuse pops immediatly
