Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-30-2005, 10:51 PM
Culzona Culzona is offline
Question Hard Starting 4.6 2002 Explorer
I have a 2002 explorer with the 4.6 engine about 2 weeks ago it started to have trouble starting, the problem is intermitent so I thought it was a fuel delivery problem. I had the fuel pump checked (was fine) and the fuel filter replaced. But that did not fix the problem.
does any one have any suggestions
please help
thanks
Old 07-01-2005, 07:56 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Hard Starting 4.6 2002 Explorer
What is it doing? Does it crank a long time before it starts? Or does it start and die? Need just a little more information please.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-01-2005, 08:44 AM
it usally starts up ok but it has died 3 times after its been starter, also it has 42,000 miles
Old 07-01-2005, 10:19 AM
way2old's Avatar
TOKEN HILLBILLY
Check the idle speed control motor. If it does it cold, and runs OK after it finally runs, that is probably the culprit. You can clean them with some success. It is a round object about 3 inches long that has a hose about 1 inch in diameter going to it and one electrical connection. It will be bolted to the throttle body.
