Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-30-2005, 09:23 PM
billyrohm billyrohm is offline
Motor Swap
If this question has been asked before I apologize
Does anybody know how hard it would be to put a late model 6.0L V8 into a 91 Suburban 3/4 ton 4wd? Would it bolt up or is there a plate made to go between the transmission and motor to make it work?
Old 07-02-2005, 09:38 AM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Motor Swap
Getting it to bolt up would be the least of your worries. you would need a new computer and harness. Not to mention a few sensors to add. It would be a costly swap.
Old 07-05-2005, 12:29 AM
94century's Avatar
94century 94century is offline
Re: Motor Swap
The transmission bolt pattern is the same on the engine block, but I would check the flywheel bolt pattern. Also you would need a reverse flow radiator and make sure the oil pan will clear the front differential housing.
