Old 06-30-2005, 05:55 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
door beeping help
hey my pass door is stupid and thinks its open when its not, basically its makin the beep and light for the door come on and off while driving, is there a way to bypass that sensor and loop it back so it always thinks its shut?
or anyone else have a solution that would help?
thanks
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 06-30-2005, 09:04 PM
jlshondacrx90 jlshondacrx90 is offline
Re: door beeping help
im having the same problem i cant figure it out either
Old 06-30-2005, 10:02 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
just unscrew those slides and disconnect the connector on the back.
Old 07-01-2005, 08:15 AM
CR50HC CR50HC is offline
Is your door out of adjustment or is the slider switch broken?
Old 07-01-2005, 04:35 PM
outofstep's Avatar
maybe a lil of both, cause the door looks like its just not completly shut from the outside, like just a slight off, but it doenst open or anything, is there a way to adj the door too? cause i tried adj the locking latch to make it shut the most it can and it still goes off
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 07-01-2005, 07:19 PM
While I'm no body man, I beleive you can adjust the door striker far enough so that your door can close all of the way. I would also check the door hinge itself as well as ensuring the slider switch is mounted securely as well. Mine was acting similar to yours. I was able to adjust the door striker so that my door closed securly.
Old 07-01-2005, 07:30 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Just disconnecting it wont work... You have to splice the 2 wires together so its a constant circuit... So splice it off, and touch the wires together it should stop... I personally would just try and find out whats wrong and fix it tho...
Try pressing the slide with your hand, if the beeping stops its the door itself... If not, its the switch...
Old 07-01-2005, 11:03 PM
honda_luvr_2000 honda_luvr_2000 is offline
Re: Re: door beeping help
wut two wires r u taking about? the "door-a-jar" switch is a grounding switch. there is only one wire running to the switch. when the door is opened, the switch closes completely the circuit for the dome light on the ground side, and the light and "beeper" come on.
to answer the problem, it sounds like the door just simply isn't closing as far as it should be. the metal "u" shaped bracket (striker) in u'r door jam is adjustable. loosen the screws, and u can slide it a little which ever direction u want to move it. sounds like u'll need to slide it in toward the inside of the car, since u door isn't closing as far as it should be. that way the striker will hold it in more firmly.
it is posible that the switch is jacked up and it shorting itself to ground, but that's easy to tell. next time it's doing that while driving, just reach over and try pulling the door shut tighter and see if the dome light goes out.
i've always found the opposite trouble with those door-a-jar switches. mine wouldn't close fully to turn the dome light on. i just took them off, cleaned off the corrosion, lubed up the slides, and they work like champs.
Originally Posted by Greenblurr93
ahh i see said the blind man to his deaf wife, as he pissed into the wind, its all coming back to me now.
Old 07-02-2005, 02:55 PM
Yes your right... It is a grounding switch, I just went out and pulled mine apart... I figured it was a 2 terminal switch that supplied 12V to complete the circuit to the bulb...
Old 07-24-2005, 05:42 AM
outofstep's Avatar
ok so i took the lil slider thing off and unplugged it, it helped a lil, but the door still beeps when i hit a bump or something it just starts going off again....
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 07-25-2005, 03:52 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
i had that problem. the pass door opened and the sound started. the door closed and it still beeped.
the beeping sound comes from the rear view mirror cover with the two seat belt lights. open up that part, unhook the wire to the small circuit board and there will be no more beep sound.
Old 07-25-2005, 03:58 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
This is sort of true for when your seatbelt light stays on. The 3 beep sound for door ajar is different though because I've unplugged the plug above the rearview but if I have my keys in the ignition and open the passenger door, it'll still beep the door ajar beep...
If you're getting the door ajar beep when your door is shut then fix your door.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 08-05-2005, 04:39 PM
outofstep's Avatar
ok well i tried the peice in the door jam loosen it up and pushed in as close to the car as it would go so it would be tight when the door shut and that didnt work either, i think the person that had the car before me was hit on the side cause its a diffrent door on that side, and my key wont work on that side, but ive had the car for 6 years and it just started this. on that note, how reliable are the electric locks? ive really wanted to get those for a long time so i dont have to use my key. how ever i still want to have the key hole incase my battery dies or something gay like that. what all i will i need to convert my manual locks to power locks?
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
