Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 06-30-2005, 05:22 PM
denkath denkath is offline
89 spirit brake problems
Hi: I have an 89 dodge spirit with 2.5L. I have brake problems that I can not seem to resolve! I put in new pads and when I pressed the brake pedal with the car off, I have a hard pedal. as soon as I start the car the pedal goes to the floor and will not pump up. I have replaced the master cylinder, booster, and bled all the brakes many times. Do not seem to be getting any air when bleeding. I capped the front port on the master cylinder and the pedal remained OK. That led me to believe the problem was in either the left front or the right rear wheel. The rear cylinder seemed like a posibility, so I put in a new one. NO help. The fluid has got to be going someplace! I am not loosing it, so it must be recurculating! Could I have a bad porporting valve? I have tried multiple master cylinders! All ideas appreciated!!!! Denkath
Old 06-30-2005, 11:26 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 89 spirit brake problems
check your metal brake lines make sure that they aren't kinked, bent, or damaged in any other way. When you get a chance, take off your wheels and crack a bleeder screw either at your front caliper or wheel cylinder; if you don't have any fluid coming out, then chances are you have a bad line or lines.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
