Old 06-30-2005, 02:50 PM
solowsilverado solowsilverado is offline
AC panel backlight to LED conversion
Here is the picture of the AC panel with blue LEDs installed:
http://img258.imageshack.us/my.php?i...cpanel29gk.jpg
I know the picture is a little blurry, but I could never get a decent pic.
Old 06-30-2005, 03:39 PM
benzero benzero is offline
awesome. now post a tutorial!
Old 07-01-2005, 07:03 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Re: AC panel backlight to LED conversion
yea, how'd u do it
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 07-03-2005, 09:03 AM
chuck16's Avatar
chuck16 chuck16 is offline
It's actually not that Hard. You just have to take the existing Lights out and wire in your 12 Volt LEDs. If you don't have any that are 12 Volt then just throw a 560 K Ohm resistor inline. I converted my Recirc/Fresh/A/C buttons once I found out that there was suppose to be lights in behind. Radioshack, eBay or Hardware store should have everything you need to do the conversion...
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 07-04-2005, 11:50 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i have not looked at a climate control on the back yet. are the bulbs exposed on the back or do you have to take the unit apart to do this? that seems to be a good mod.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 07-04-2005, 12:57 PM
chuck16's Avatar
You have to take the HVAC Control Module apart but, it's just 6-8 Screws and the control knobs just pull off. Seems to me one of them was really hard to remove...
Hope that helps...
2008 GMC ACADIA
I AM Canadian!!
Old 07-04-2005, 01:09 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
and if you have the 12v LED's then you dont need the resistor correct??? you just take the old bulbs out and solder the new ones in?? how many bulbs are there by the way.
one more question, is it possible to do this to the radio controls also?
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 07-04-2005, 01:16 PM
chuck16's Avatar
Hmmm good question, I believe there are 4 or 6 lights. Can't remember exactly. Yes 12 Volt ones should just work. What I did was wired in my LEDS then plugged it in minus the front just to make sure it worked. Left it on for about 2 minutes just to make sure they didn't burn out. It doesn't take long to cook them if they are the wrong ones. I had just wired the ones I had straight in the first time and they died in like 30 seconds...
As for the radio controls. I'd like to think that you can do it but, I've tried twice to get the front of the CD player off and each time I've broken more Lights. I still haven't been able to get the face of the player off completely yet. If you do get it to come off take lots of step by step pics for me.
2008 GMC ACADIA
I AM Canadian!!
Old 07-04-2005, 01:18 PM
korndogg's Avatar
ok cause like 3 of my radio lights went out but im going to take a good look at it and see if I can get it off.
and what do you mean the ones you wired straight in blew in like 30 seconds? what do you mean by straight in...were they the wrong ones?
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 07-04-2005, 01:26 PM
chuck16's Avatar
Yeah, I just had some LEDs kicking around the shop that obviously weren't 12v rated. Thus, I needed the resistor to drop the voltage.
I know what you mean about the radio the whole driver side of my stereo lights don't work.
2008 GMC ACADIA
I AM Canadian!!
Old 07-04-2005, 01:32 PM
korndogg's Avatar
alright...well ill let you know if i figure out a way to open her up.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 07-04-2005, 03:10 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Please let us know how hard the radio is. I have very few lights left so I have to turn on the overhead to change anything but the volume...
Old 07-04-2005, 03:47 PM
chuck16's Avatar
It's not too hard to remove the face and get it loose it's getting it all the way off without feeling like your going to break something that's the problem.
2008 GMC ACADIA
I AM Canadian!!
Old 07-04-2005, 04:22 PM
korndogg's Avatar
one more question. what size and shape are these bulbs?? or doesnt it matter??? i found a link with a bunch of LEDs but theres like every shape and size.
http://www.ledtronics.com/ds/L200-xPB/
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 07-04-2005, 06:01 PM
chuck16's Avatar
Wow I never knew there were so many. I used L190 style ones in the Recirc/Fresh and A/C but, if I were to do it again I would use the L190 in the main area behind the knobs and the LD120 in the recirc/fresh, a/c buttons. The 120s are smaller and would probably be easier to use.
Just my worth!
2008 GMC ACADIA
I AM Canadian!!
