Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-30-2005, 02:47 PM
Brianinthenorth Brianinthenorth is offline
Question solenoids on a 1975 caprice 454 cid
I need to find out where my vacuum lines run from two engine solenoids ? My 75 Caprice 454 engine has two electric solenoids on the passenger side, rear area, on either side of the valve cover. Each solenoid has 3 vacuum lines running off of it. One line off the back and a tee with 2 lines in the front of the solenoid. All the lines are missing, and I would like to find out the proper layout of these vacuum lines. So if anybody has the same engine or knows of any information that can help me out. That would be fantastic.
Old 09-13-2005, 11:53 AM
convertible1975 convertible1975 is offline
Re: solenoids on a 1975 caprice 454 cid
I have the Chevrolet book on the vaccum hose hook-up for the 1975 454 engine. I also own a 1975 caprice classic with the 454 engine. if you want I can fax you a copy of the vaccum hook -up. tom
Old 09-13-2005, 12:11 PM
i can fax you the vaccum hose hook-up. I.have the gm book. please e-mail me.i also own a 1975 454 caprice !tom
Old 09-20-2005, 12:46 PM
e-mail at [email protected] for vaccum set-up.i can fax over you a copy from the gm book. tom
Old 02-19-2006, 12:09 PM
LA-CUSTOMS's Avatar
LA-CUSTOMS LA-CUSTOMS is offline
this should not be here guys !!
-----CURRENT PROJECT: FORD ESCORT------_
----CURRENT PROJECT : FORD ESCORT----
Old 02-19-2006, 09:57 PM
broughy84's Avatar
broughy84 broughy84 is offline
why not what's wrong with it?
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 02-20-2006, 01:51 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
wtf are you smoking, this is in the right place
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 02-20-2006, 10:18 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I think he's referring to the fax numbers, etc. That stuff should be in PM, lest a thousand faxes commence due to the fax number being made available on the Internet.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-27-2006, 12:39 PM
1986Z28's Avatar
Has a Camaro
yay im going to spam him
