Old 06-30-2005, 01:51 PM
Knight2040's Avatar
Knight2040 Knight2040 is offline
Send a message via AIM to Knight2040
eclipse GST turbo
hey guys, my buddy recently totaled his 98 Eclipse GST and he told me that the stock t25 turbo off his car would directly bolt on to my VR4. is this true? can i run mismatch turbos untill i get another one? is it worth it to swap? what are the power increase i can excpet if this is possible? would it be difficult? thanks guys!
1991 Mitsubishi 3000GT VR4 Twin Turbo- Forged Ross Pistons,Forged Crank,Forged and Shotpeened Rods,Stillin DP,K&N FIPK,Greddy Type-RS BOV,Magnacor Wires,Aluminum Y-Pipe,EGR Blocked,All Gutted Cats,Greddy Turbo Timer,Blitz Boost Guage,Autometer A\F Guage,Solid Shift Bushings,Red Top Batt,ACT 6 Puck Clutch,Free Boost Mod,99 Front End Conversion
Old 06-30-2005, 03:14 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: eclipse GST turbo
no its not true
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 06-30-2005, 08:35 PM
Hotshot8792 Hotshot8792 is offline
The T-25 is not a direct bolt on, and it's not even a good enough turbo to try to make work with our cars. As far as the DSM turbos go, there's two ways to do it.
#1 - get a turbo off of a 1st gen automatic (TD04 13G), and put it on your current turbine housings (might have to bore it out just a little bit) and you got yourself 13G's. Or, if you want to get the first gen manual turbos (TD05 14B's) then you'd have to go with either TD05 manifolds or adapter plates if your lucky enough to find those, and those turbos have proven nearly 500 AWHP, and i think there has been some cases with more than that. Either way, i'd stay away from the 2G turbos all together.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-30-2005, 10:44 PM
Knight2040's Avatar
Re: Re: eclipse GST turbo
well...thanks alot for the info! so from the 1G and 2G's your reffer to eclpises right? theres a manual turbo laser at my local junk yard, will that turbo fit?
Old 07-01-2005, 12:03 AM
No it will not, has to be an automatic with a small lip turbo. I dont know what small lip turbo means, I just know its part of the turbine housing.
Old 07-01-2005, 02:54 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
hmm didnt relize they made the tubros dif from autos to standered on the 1st gen dsms... but yeah the 2nd gen turbos have dif fittings. you need td04 fitting i think 2g dsm have t6t4.
go to www.DSMTrader.com they are loaded with stuff like that.
Upgrades... To many to list...
Old 07-01-2005, 03:23 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Putting a t25 turbo into a vr4 will only make it slower and it wouldnt even fit/bolt on anyways. Your best choice are the 1's Hotshot8792 described to you.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 07-01-2005, 07:35 PM
The lip of the turbine housing where the cartridge actually sits in, are different b/t the 1st gen and 2nd gen VR-4s. On the second gen turbine housings, the lip is further in, so if you try to stick a 2nd gen cartridge on a 1st gen turbine housing, you will realize that the cartridge does not go all the way in. This was the case when i made my 18T's because i had 1st gen turbine housings, so i had to take it to the local machine shop, and they grinded it down to the correct specs on both turbos for 50 bucks.
