Old 06-30-2005, 01:16 PM
noctorum noctorum is offline
Material Strength
Aluminum is stronger than forged iron, forged iron is stronger than cast.
Correct?
Old 06-30-2005, 01:56 PM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
This answer can not be answered in a definitive "Yes" or "No". I'm assuming that even though you said Forged Iron, you mean Forged Steel. Iron is rarely used in anything automotive. Although it has a high strengths, it is extremely brittle and will crack/stress fracture easily. Forged almunium is generally not as strong as forged steel but is a lot lighter.
This website gives a nice summary on the different strengths and characteristics
http://www.63xc.com/scotn/metal.htm
This website gives specific numbers:
http://www.thedirtforum.com/materials.htm
More detailed information can be found by going to a library and researching "metallurgy" for about 30 min. I would def reccomend taking some time doing this if you plan on any modifications as most cars are, (you guessed it) based on metals and alloys.
Joe
Old 06-30-2005, 08:18 PM
Reed Reed is offline
Send a message via AIM to Reed
Re: Material Strength
actuall iron is used quite extensively in engine blocks.
Cars are like music.
If it ain't fast it ain't shit.
Old 06-30-2005, 09:32 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Material--------------------Elastic Strength tens. (ksi)---- Ultimate Strength tens. (ksi)
Wrought iron----------------------30--------------------------48
Cast iron - malleable---------------32--------------------------50
Cast iron - nodular-----------------70--------------------------100
Aluminum Cast, 195-T6-------------24--------------------------36
Aluminum wrought, 2014-T4--------41--------------------------62
Aluminum wrought, 2024-T4--------48--------------------------68
Aluminum wrought, 6061-T6--------40--------------------------45
Steel SAE 4340--------------------132-------------------------150
Heres just a few out of my strength of materials book.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
