Go Back   Automotive Forums Car Chat > Toyota > Sienna
Old 06-30-2005, 10:29 AM
JLauto05 JLauto05 is offline
Question need keyless remote programming for 99 XLE w/1 Power Sliding Door
hi everyone - i recently purchased a 99 XLE w/1 power sliding door, and it came with 2 keyless remotes but neither works (even with new batteries)
i think i need keyless remote programming for 99 XLE w/1 Power Sliding Door. in another thread, "big yellow monkey" posted keyless remote programming instructions for the remotes with NO power sliding door - thanks biggie!!
those instructions have two parts:
- steps 1 through 5 enter the sienna into programming mode (this part WORKS for my sienna as well)
- steps 6 and 7 program the remotes (this part works for the 2 button remotes, but not for my 3 button remotes because i have the power sliding door model)
can someone who has the 3 button remotes post the programming instructions?
Old 04-23-2006, 11:01 AM
babakara babakara is offline
Re: need keyless remote programming for 99 XLE w/1 Power Sliding Door
Hello I am giving you the programming code for the toyota sienna 1999 XLE
1. yOU ARE IN THE DRIVRS SEAT.
a. key is out of the ignition
b.driver door is open all other doors closed
c.driver door is unlocked other doors don't matter
2. Insert and remove the key from the ignition twice within 5 seconds
3. close and open the drivers door twice within 40 seconds
4. Insert the key into the ignition and remove it
5.Close and open the drivers door twice within 40 seconds
6. Insert the key into the ignition
7. Close the door
8. t urn the key in the ignition on and then off.
9. remove the key in the ignition.
10 The power locks should automatically cycle once to indicate that you have successfully entered program mode
11. Within 40 seconds of the entering program mode
a. press both transmitter lock button for more than 1 second and release.
b.within 3 secondspress the transmitter lock button for more than 1 second and release
c. if the transmitter has been successfully programmed, the power locks will automatically cycle once. If they cycle twice, the remote has not been accepted.
AS FAR AS I AM CONCERNED I NEED THE PROGAMME FOR TRANPONDER BLANK KEY
