Old 06-30-2005, 08:57 AM
Sparsky Sparsky is offline
obd0 to obd1 questions
Tried searching for the answers to my questions but no luck.
88 CRX Si (d16a6)
I know I have to change the dizzy out, then get a wiring harness from hassport. But what ECU should I pick up? I'm tring to figure out how to wire up this motor for a hondata. Anyextra info, tips or tricks would be apreciated.
http://www.cardomain.com/memberpage/765867
Old 06-30-2005, 09:10 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: obd0 to obd1 questions
I would think that you should use a distributor from a 3rd gen civic with an mpfi 1.6l non-vtec.
What are you trying to achieve with your A6? Is it built up or are you just trying to raise the rev-limiter and/or better the fuel maps with the Hondata ECU.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-30-2005, 10:06 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
P06 is what you want
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 06-30-2005, 11:36 AM
Oh sorry, guess I should've gave yall a little more info. I'm getting a d16a6 motor built up for boost.
Old 06-30-2005, 03:18 PM
Kunundrum's Avatar
yeah get a P06 and get it chipped, (p06 = Non-vtec SOHC)
Old 06-30-2005, 05:55 PM
now when you say chipped... is it one of them 15 dollar Spoon chips they sell on ebay?
Know of anyplace I can buy one already chipped? I'd hate to get one off e-bay and it not work. And I'm sure Honda would want a small fortune for one.
Old 06-30-2005, 10:33 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Why go OBD1 with that engine? I personally would go preOBD and run Turboedit on a chipped PM6... Would save u alot more money than OBD and Hondata...
Chipped means someone solders on a socket that allows you to run those $5 chips on ebay, or preferably, a chip tailored to your setup...
Old 06-30-2005, 11:44 PM
Seems around here Hondata it popular and cheap to tune. I've mentioned Crome and Uber but most are not familar with them. I'd rather shell out the extra cash and get something that everyone's familiar with and cheap to tune. Plus I hear the Hondata is user friendly, so I can play with it too. (When I understand everything a little better.)
I will look into the Turboedit though. I haven't asked around about them. You happen to know what size injactors they max out at? I know the SAFC is only rated for 450 injectors, anything above that I'd have to get a hondata, no one has mentioned turboedit. I'm planing on 500+ injectors eventually.
The setup I want to run is going to be a stage 4 exospeed block with stage 2 head work. People say I'm shooting low when I want a 300hp rex with all the work being done. But no one will say how much HP and fully built exo block will handle. Plus after the 300 mark I'd have to upgrade fuel lines, hubs, suspension, etc. So for now I'm shooting a little low, but want everything to where it can be upgraded with out buying all new stuff.
Old 07-01-2005, 03:46 PM
Im not sure about the injectors... Might be able to find that info out here tho: http://www.turboedit.org/ ....
But Turboedit is basically the same as Crome and Uber (give or take a few things), only its designed for preOBD (and I think OBD1 awell) ECUs, where as Crome and Uber are strictly OBD1... Which they are programs you run on your PC, and allow u to load up a base map of the specified ECU (Fuel maps, VTEC engagement points, ect), tweak them, and then save them to ROM file, that if u have a ROM burner, you can burn to a PROM to use in that chipped socket on your ECU...
