Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 06-30-2005, 07:53 AM
jarekt jarekt is offline
hot emergency break handle
I'm wonder if anyone have issue with quite hot spot on tunnel next to gear box shifter /emergency break (handle is hot too) -driver site only.
Old 06-30-2005, 08:27 AM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: hot emergency break handle
It will get warm after alot of driving from the exhaust, but it shouldn't get anywhere near hot. Are all of your heat shields installed still? You should heat wrap the DP and exhaust up to that point if you're worried about it.
Old 06-30-2005, 08:50 AM
heat
well, i just drove this car from dealer for first time on hwy for 120KM and noticed heat. what should i check? one more issue i noticed is vibration on 5th gear. tranny bearing?
Old 08-24-2005, 04:20 PM
GadflyII's Avatar
GadflyII GadflyII is offline
Take it back to the dealer and make them fix the transmission and install missing heatshields.
94 Supra Turbo 6spd
Ported head w/ 1mm over sized valves
6pt cage w/ removable door bars
SP67 Single Turbo .81 A/R
RPS Manifold
SP fuel sys w/ 1000cc injectors, SP rail, & Dual Walboro pumps
Aeromotive FP regulator
Greddy 3 Row front mount
Tail BOV
TRD Rear Diff
TRD dual disk clutch
HKS Racing Wastegate
HKS DLI
HKS VPC
HKS BCC
HKS EBC
FJO Wideband o2
Greddy Electronic Boost, EGT, Fuel pressure w/ Peak & hold
98 tail and headlights
Wings West lip
