Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-30-2005, 07:52 AM
'92 Olds from texa '92 Olds from texa is offline
Send a message via Yahoo to '92 Olds from texa
i have two ?'s
i have a '92 Olds cutlass sup. And my passenger window will not let down, i can hear the motor running but it's not coming down. My second problem is i have a digital insturment panel and it will not come on when the car is on. it does it like every now and then like in the mornings it comes on, or if it's been sitting for a long period of time or when i'm driving for a long period of time, i turn the car off and start it panel will not come on.
'92 Olds from texas
Old 07-08-2005, 07:58 PM
Stormysdad Stormysdad is offline
sounds like you need a new window regulator tape or regulator assembly, esp. if the motor is running. The cluster problem sounds like a heat related failure of the printed circuit on the back of it.
Old 07-13-2005, 08:51 AM
so do i need to get a new window motor/ and new cluster panel. or is there a way that i bypass buying a new one and fix the one i have.
'92 Olds from texas
Old 07-13-2005, 10:28 PM
Don't necessarily need new, good working condition wiill do. Find a good reputable junkyard . Just make sure the parts you buy come with some warranty in case they don't fix your conditions.
