Go Back   Automotive Forums Car Chat > Audi > Older Vehicles > 4000/100/A6/S6
Old 06-30-2005, 06:35 AM
niteshadw niteshadw is offline
Over heat
I have a 1991 Audi 100. The car's fan's have two phases but they only turn on once the red over heat lamp in the car turns on, I was wondering if anyone knows what would cause this to happen; what controls the temperature. Also, if anyone knows the location of radiator fan motor resistor.
Thank you.
Old 04-14-2006, 02:13 AM
stv840 stv840 is offline
Re: Over heat
if fan dosn't run in high ck thermo switch located botom right of radiator ohm it out should turn on at 190-200 deg F if ok ck relay # 7 botom left in axsilery box under drivers steering wheel panel most likely thermo switch resistor may be integrated in fan not sure but can ck
