ECU recommendations and fuel controller?
Right now, my car is running SUPER rich, while....yes we all know that that is safe...it's not making the power the car could be making
I was thinking about an SAFC, but I heard that its worthless for the SR20DET. I heard many people just have their ecu's flashed. I'm definitely leaning toward the ecu flash. THe car could do much better with some sort of ecu flash and tuning. It starts leaning out at 6000 rpm and you get this surge of power. Any suggestions? |
it starts leaning out at 6000 rpm or its running rich? which is it?
![]() "I got that hustle in my genes like high blood pressure" -E-40 |
Re: ECU recommendations and fuel controller?
im pretty sure what he is saying is while at idle or cruising rpm...his car is probably running like 14/1 ratio and when he gets his car moving pretty good aka 6'g' rpm its sucking fuel enough to be back down to 12.1 or around there...yea figure if you get your ecu reprogrammed its 500 bucks for an enthalpy one and if you do later mods it costs only 125 to redo it...
Current cars: 83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5 |
SAFC ? what is wrong w SAFC?!
u neeeed t dyno tune it... why is it running rich? stock ECU? did u put a biggr Injectors? how is the fule regulator? makes no sence!!! and how did u figur out that ur r runing rich?
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car" E.K. |
Its probably leaning out at 6k because voltage to the fuel pump is dropping. Or you may still have the stock pump(which isn't a bright idea at all).
How are you sure its running rich? BTW, running really rich isn't safe either. Too much fuel washes oil off the cylinder walls causing increased cylinder wear. Check for a boost leak. And list your mods please. Its hard to know whats wrong when you don't know what it is....
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
I don't think I'm running really rich. Plus, running rich is better than running too lean. Most cars run rich stock for protection purposes. My car has these mods.
Blitz Nur Spec Exhaust Greddy Downpipe HKS adjustable cam gears Apex'i intake That's all the power mods that I have. Maybe it could be the cams need tuning cause the timing may be off? Possibly advance the timing on the intake and retard the timing on the exhaust. |
Re: Re: ECU recommendations and fuel controller?
If you dont have a fuel pump. thats why... and your about to fuck your ringlands. SAFCs are more of a bandaid than a fix... that being said they do work well for what they are. An T25 SR20 with a surge of power at 6000 RPM
