Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-30-2005, 02:49 AM
homerunhitta homerunhitta is offline
93 deville door panel removal
Does anyone no how to remove the door panels of the 93 sedan deville. I got all the screws out of it which was 6 all together and then popped out all the clips around it. It still seems like there is something holding the center of the panel. im just trying to put speakers in it. also is it possible to put 6.5 size speakers.
Old 01-04-2006, 07:14 PM
PHATPATT PHATPATT is offline
Re: 93 deville door panel removal
IAM HAVING THE SAME PROB ON MY 91 DEVILLE, I KNOW EXACTLY WHAT YOUR TALKING ABOUT AND i ALMOST BROKE THE DAMN THING TRING TO GET IT OFF
Old 01-04-2006, 08:39 PM
caddydaddy caddydaddy is offline
Check behind where the inner door handle is. There may be a screw there holding it.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 01-05-2006, 08:29 AM
DFBonnett DFBonnett is offline
From the $20 Chilton manual.....
Disconnect negative bat terminal
Insert flat bladed tool between door panel and the rear edge of the PW switch plate to disengage the retainer from the panel.
Slide the PW switch plate forward then disconnect wiring connectors
Remove pull handle retaining screws
Using thin bladed tool pry courtesy lamp lenses off
Remove bulb
Pinch courtesy lamp retainers and pull out lamp socket
Disconnect courtesy lamp wiring connector
Remove door panel retaining screws
Using tool J-2459B or equivalent, disengage the door panel fasteners from the holes in the door
Disconnect any remaining wiring and remove panel.
Old 08-23-2007, 11:48 PM
nicks84 nicks84 is offline
Remove bulb
Sweet, by any chance, is that the same process for a 94, I thought they changed body style in 94, so , it might be different ? Or similar enough ?
Old 08-25-2007, 06:58 AM
Don't know. Manual says for 90-93.
Old 08-25-2007, 11:26 AM
Thanks man, I appreciate you lookin out.
