Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 06-30-2005, 03:36 AM
jonnysos11 jonnysos11 is offline
99 civic power windows..help
i have a 99 civic dx and the window keeps coming off the track i believe there was a factory reecall to fix the problem but was thinking i could fix it myself any advice on how to fix it?????
Old 06-30-2005, 03:50 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: 99 civic power windows..help
pull the window out. clean the track and realign the window back in.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 06-30-2005, 04:28 AM
to my understanding the recall was to replace a washer thanks for the feedback any way
Old 06-30-2005, 05:29 AM
AF - Advisor
what window are you talking about? the windshield?
Old 06-30-2005, 06:47 AM
the driver side window.it falls off the track
Old 08-10-2005, 10:26 PM
terry5581 terry5581 is offline
Angry me too
Without a doubt, every winter my driver side window will go off track constantly. It got to the point that I don't even use it in the winter cause I know the same thing will happen. It seems the civics and accords have a lot of problems w/ their windows. My sister & mother have window problems and a door on the accord just decided one day to never open again. The cars got good engines, but for those simple things, too many problems.
Well anyways, honda denies its anything that has to do w/ them regarding the windows, so good luck & if you figure anything out let me know.
Old 08-16-2005, 02:37 PM
mattcivic's Avatar
mattcivic mattcivic is offline
I had the same problem with my 99. Both windows would fall off the track, especially in the colder weather. If you remove the door panel, down behind the speaker you will see a small bolt. Loosen it a litlle, and than slide the track closer to the window(once you have the window back in the track) and hold it tight while you tighten the bolt. It will eventually slip out, but it does help. I have a 00 now, and I hope I don't run into this problem again. If you find a permanent solutio for this problem, let me know. I have a buddy who is a Honda Tech, if I see him I will ask to see what he thinks.
Old 08-19-2005, 04:16 AM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
Ever wash your civic?
Ever notice that after you wash it, and of course, clean the windows, that if you roll it down then back up, the windows are wet?
Funny thing about 5th and 6th gen civics...there aint too much keeping the outside crap out from inside the door panel. Betcha the window started to stick when you cranked it, or the motor did, before it popped track huh?
Now, I could be full of crap...but...after torching and bending, and eventually replacing, 3 window regulator arms in my 2 past hatches (92, and 97 respectively) I've come to realize that the window, arm, and track are fine...it's the weather stripping that doesn't work worth a damn.
The cold doesn't cause the problem, the salt, snow, and ice that makes its way into your door does.
The cheap "grease" that is used to lubricate the door eventually runs off the very bare, very untreated metal that makes your window work.
Take off the panel, get up in there, clean the thing out with some WD-40 then put some clean heavy grease on there and work it into the arm and the pivot. Good to go...until it washes out again...give it a year.
If that don't fix it....well damn...
PM me if you need help getting the door apart.
"Why yes, this is a GS-R."
