Go Back   Automotive Forums Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 06-30-2005, 12:29 AM
Texas_Juvy Texas_Juvy is offline
Send a message via AIM to Texas_Juvy Send a message via Yahoo to Texas_Juvy
Need some advice/help installing:Washer Nozzle LEDs.
OK...I have the Hood LEDs on and installed except for one small problem, i have no idea where or how to run the wires from the hood...into the car and under my seat. I have an LED underglow kit installed but didnt do it myself, had it proffessionally done. It looks nice and i have a wireless remote and toggle switches to change the 10 patterns of the neon. But i wanted to gain some experience and install the hood neons manually, can anyone Help me? Oh and I drive an '02 neon...and no its not stock its completely modified.
Old 06-30-2005, 07:32 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Need some advice/help installing:Washer Nozzle LEDs.
run the wires to the switched power of your corner lights (not the blinking wire)
Old 07-02-2005, 09:27 PM
PBking82 PBking82 is offline
What exactly are you trying to do here? make the LED's turn on when you squirt washer fluid onto your windshield? If that's the case, why do you need to run the wires under your seat? If you want them just on/off run the wires down the hood through the firewall then into a switch whereever you want them. If you want them to flash when you squirt the juice, wire up a relay from the motor on the pump that moves the washer fluid. That way whenever the pump is activated the relay will send power to the LED's. Also, if you do it this way you will still need to independantly power the LED's, you can't just run them off of the power being supplied to the pump. Hope this helps you out. Peace-
Old 07-29-2005, 12:12 AM
HeWhoKillz HeWhoKillz is offline
or do what i did, run them into the headlights, hook them up to the fuses
Old 07-29-2005, 01:57 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
of course if you hook them up to your headlights they'd come on all the time and be illegal (unless they're white and they'd just look dumb)
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
