Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-29-2005, 11:20 PM
apeay apeay is offline
99' GMC driving problems
My 99' GMC Jimmy has a problem with driving occassionally. Sometimes around half a tank or lower it will not accelerate and will just die completely. at this point it wont start back for about a hour or until i fill the tank back up with gas. If it does start it only stays on until the gas pedal is pressed and then it dies immediatly. I can tell when it is going to happens because the engies begins to make weird noises and sound funny. Please Help!
Old 06-30-2005, 06:21 AM
cmoore992002 cmoore992002 is offline
You might try replacing the gas cap. A bad cap will cause pressure problems and the symptoms you describe.
Charlie M.
Dallas, Tx
Old 06-30-2005, 11:25 AM
My gas cap was pressure checked about two months ago at the DMV. I also put alcohol or engine treatment in my gas when this happens and it allows it to run again.
Old 08-09-2005, 07:52 PM
dinsinger dinsinger is offline
You might want to replace fuel filter. That could be causing your problem. should be changed every 30,000 or so.
Old 08-11-2005, 01:44 PM
dtl379 dtl379 is offline
Re: 99' GMC driving problems
If all the help above fails, have the sending unit checked. It may have an intermittent fault that causes it to read half tank when it actually is empty. Also, start using the trip and keep track of your miles. We lost the sending unit in our truck over 2.5 years ago, but we never ran out of gas because we saw the trip miles. So now we fill the tank, reset the trip, and know that just past 300 miles we need to refill.
