Old 06-29-2005, 11:02 PM
arnel555 arnel555 is offline
Send a message via AIM to arnel555 Send a message via Yahoo to arnel555
Arrow Engin issue
Hey you guys well I am new to the forms so I got a relay quick question ok well I have a 95 mitcubuse eclipse gs ok well I had an issue with the water pump and it seized up and started overheating my car so I took it to a nother bad mechanic well he replaced the water pump and my timing belt. came back to pick it up and the angina was shaking and idling did no know what it was well her are the symptoms now the car can NOT reve up to 7 thousand rpm it goes to 5 thousand and it sounds like it is like on 7 I could reve it up to 7 but I think I could damage the engine which leads me to believe that one of the cylinder was not firing replace all spark plugs and spark wires and still it sound like it is running on 3 cylinders and it still shakes could this be caused by the machining not setting the timing belt right or a bad sencer any info would be great.
Old 06-29-2005, 11:26 PM
TgDn32 TgDn32 is offline
WTF.
Punctuation, spelling, grammar.
Old 06-29-2005, 11:48 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: Engin issue
Punctuation, spelling, AND grammar.***
Old 06-30-2005, 12:00 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Engin issue
The ECU would throw a code for misfire. Read your codes and do the normal diagnostics... check for spark, injector pulse, compression, etc..
Old 06-30-2005, 04:07 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Engin issue
u need to learn how to spel and write sentancs that actually make sense because if like you dont than like no one can really undrstnd u and that is jst isnt cool because evry 1 gets pissed off and howe is tht questAN a rally quick questian huh casue its like so dam long and unreadable...
ANYWAY, as for your question...let me get this straight. why would you want to sit there and rev the motor to 7grand?
"now the car can NOT reve up to 7 thousand rpm it goes to 5 thousand and it sounds like it is like on 7 I could reve it up to 7 but I think I could damage the engine"
i'm sorry but that just makes no fucking sense. you say it will NOT rev to 7grand, only to 5grand. but it SOUNDS like it's 7grand, and you COULD rev to 7grand but you don't want to damage your motor. WTF!? that sentence is a nightmare. from what i know, if the timing was a bit off the motor could run shitty. check to make sure you're getting spark out of all 4 wires. easy way to do it is start the motor, pull out each wire one by one and TOUCH it. if you get shocked 4 times then you have spark and then i can laugh at you. as for the plugs, make sure they are all properly gapped. make sure your wires aren't falling apart too. if none of that works, take the plugs out. see if any have oil all over them. let's say one does. that would cause a misfire because the plug isn't sparking. this could mean a bad valve cover gasket, or even worse, a fried piston ring. and if all that checks to be normal, take your 3 cylinder gs back to your whack mech and have him fix the problem so he can make it run on all 4 again of course, IF it is in fact misfiring...it's probably running like this from you revving it to 7grand constantly. would would anyone just rev the motor to 7k every now and then to see if it "sounds right"? ahh this thread gave me a headache. now, for the time it took me to read this and reply i want you to send me some tylenol and $5 so i can get some taco bell.
Old 06-30-2005, 03:57 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
^^^LMFAO
I kind of expected someone who didn't look like they graduated from middle school by them not spelling "engine" correctly on the title. Was worse than I thought after I read that paragraph, if you call it that, of complete garbage.
This ones easy. Your cars a piece of shit man. Stop reving the shit out of it and pretending you are on fast and the furious everytime you come to a light, and it wont shit out on you.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-30-2005, 07:06 PM
Re: Engin issue
wow.. those are some brutel replyes. i know i suck at spelling but what the hell can i do? take spelling corses.. hell no... anyways i got the stupid issue fixed. it was just the timing belt not being set right.. took it back and the guy fixed it...
Old 06-30-2005, 07:59 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Re: Re: Engin issue
Sorry, but the irony here is hilarious.
Hopefully the timing belt being a but off didn't cause any problems. The 'head room' available isn't much on these motors.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
