Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 06-29-2005, 07:31 PM
fbi-interceptor fbi-interceptor is offline
Send a message via Yahoo to fbi-interceptor
Gas Tank Size/ Mpg
Does Anyone Know How Many Gallon Tank They Put On The 93 Cvpi? I Believe Its 20 But I Wanted To Be Sure. And How Many Miles Do Some Of Yins Guys Get Out Of A Tank? I Would Really Like To Compare Some Different Mpg In Some Of Our Cars
[/IMG]
Old 06-30-2005, 12:55 PM
jimmytroanoke jimmytroanoke is offline
Re: Gas Tank Size/ Mpg
YINS Guys? You must be near Dahntahn Pixburgh! I grew up in the South Hills. I average 27 Hwy and 19-20 City. can sometimes get 500 out of a tank on the highway.
2001 Grand Prix SE 3.1 - Someone elses problem now!
95 Grand Marquis - Will outlive all of them!
97 F-150
2004 Toyota Avalon
Old 06-30-2005, 06:30 PM
yes jimmy t i live in the mckeesport area. but its always good to year from an x pittsburgher, anyway i think im only getting about 13 mpg. i guess i should change the plugs and wires then see what happens. after that i guess it o2 sensor time
[/IMG]
Old 06-30-2005, 07:14 PM
BiggerJon BiggerJon is offline
i had a 94 vic(same), it had a 20 gallon tank and i would get anywhere from 22-30mpg. it had 3.08 gears.
Mods
Old 07-01-2005, 12:45 PM
If you are only getting 13 a major tuneup is a good place to start. Stick with Motorcraft platinum - Don't put Bosch plugs in. The motorcrafts are the only thing that has lasted more than 20k in my car. New air filter, clean Maf sensor and Throttle body, Make sure Egr passages are not blocked, and do a fuel filter while you are at it. Pick up a Motorcraft PCV valve while you are at the parts counter. Check all your vacuum hoses, especially the one between the PCV hard line and the intake - famous for clllapsing and getting holes in it. The oil does a number on them.
97 F-150
2004 Toyota Avalon
Old 07-03-2005, 02:58 PM
i cleaned my maf sensor, new air filter, new fuel filter, and new pcv valve, its a motorcraft one. how do you check to see if egr passages r blocked? for the throttle body is there anything special to do for that except just using carb cleaner? i also have to check vacuum lines. also what is a good website for motorcraft parts?
[/IMG]
Old 07-05-2005, 11:29 AM
Re: Re: Gas Tank Size/ Mpg
For your EGR passages unbolt the elbow that your throttle body is attached to from the manifold. under the gasket you will see a horseshoe shaped passage that is probably full of guck. easiest to shopvac it out and run a rod down the port to the egr valve.
97 F-150
2004 Toyota Avalon
Old 07-05-2005, 02:59 PM
thanks man. i will give it a try.
[/IMG]
Old 07-07-2005, 02:12 PM
i just checked my gas mileage again, i got about 315 miles out of a tank with some highway but mostly town driving with ac on. its about 15 mpg. is that pretty bad?
[/IMG]
Old 07-07-2005, 02:25 PM
How are you figuring your MPG? Are you dividing your miles by the tank size or by the number of gallons you used to fill up? To get a number that low, you must be dividing 315 by 20.5 = 15.4. You did not use the whole tank, tho, only what it took to fill up unless you ran it dry. If your fillup took 18 gal, 315/18=17.5 mpg. That sounds a little more reasonable. To check gas mileage, fill tank and reset trip odometer. At next fillup take the miles on the trip meter and divide by the gallons it takes to fill it back up. This is the actual gallons used. The tank size has nothing to do with MPG. If you are getting 17-18 out of it in PGH you are probably ok. PGH is kind of hilly and as I remember, has a traffic light every 50 ft! Not conducive to the best mileage!
97 F-150
2004 Toyota Avalon
Old 07-07-2005, 05:00 PM
yes that makes sence i will try that. so how big is this gas tank exactly?? are they all the same or are they different?
[/IMG]
Old 07-08-2005, 07:05 AM
I think my manual lists it at 20.5 - for a 95, but probably the same as yours.
97 F-150
2004 Toyota Avalon
Old 07-08-2005, 10:51 AM
well i just cleaned my throttle body, all it takes to remove is 1 anchor bolt and a clamp. the inside of the body had some tarnish built up inside. i could see it run out when i sprayed the injection cleaner inside it. i will check to see if this improves gas mileage then i will get back with yins guys/
[/IMG]
Old 07-11-2005, 04:13 PM
well i just took a trip, and checked my mileage. i got 26.7 miles per gallon. i guess this is ok mileage but im not sure. i also had the ac running about 90% of the time.
[/IMG]
Old 07-11-2005, 04:54 PM
tkhilliard's Avatar
tkhilliard tkhilliard is offline
on my 93 p71, on a full tank usually will get between 320 and 350 miles on 3/4 tank. i never let it hit below the 1/4 tank mark. unless i drive it hard then it gets about 280.
Closed Thread
