Go Back   Automotive Forums Car Chat > Buick > Century
Old 06-29-2005, 07:25 PM
msgdew msgdew is offline
Window switch
Front Drv and pax switches do not work. If u turn the long plug on back around then the r/f will then work. Once connecting the other plug backwards let the r/r control the left frt window so it went down but now can't get it back up. I do not appear to have any broken wires in door boots and its only the frt switches that don't work. Also tried new switch w/same results. Any help is appreciated and does anyone know how to jump the plugs to make the front windows go up, thanks.
Problem solved, each plug has own grd wire and the front grd wire was broken, put on clip and bolted to window motor mount and all fine now.
