Old 06-29-2005, 05:04 PM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
Question Help!?!
Ok here it is...I took my car to the body shop to have some damage on it repaired. The shop was ok but I wouldnt say trust worthy the car looks good.But it was being driven around by someone else that was doing the frame work. I thought the guy at the body shop was going to do the work on site. I get the car back and it is running shitty like someone was doggin it bad!! It runs find in park but in any other gear it shakes pretty bad(when moving slow or at a stop)other wise cant tell when pressing the gas. I thinking it could be a vaccum leak but I really dont know. I know my ICM sensor is bad but it did not have this problem before.
http://www.cardomain.com/ride/631458
_______________
92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat
Old 06-29-2005, 05:08 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Well it may now start taking real bad effect! Replace it dude, it probably will fix the problem with the shaking.
Old 06-29-2005, 05:14 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Help!?!
replace the bad part, and go from there. The ICM would definatly cause those symptoms.
Also with the type of repair work you were having done, its very possible that they pinched, cut, damaged, or forgot to connect a wireing harness of some sort. which would throw off the driveability depending on what was connected to the harness.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-29-2005, 05:42 PM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
Whenever you bring your car (especially a nice, muscle type car) to some kind of independent mechanic/body shop, always write your cars mileage down, and make sure the people working on it see you do it. If there are more miles when you go to pick it up bring it up to the mechanis and ask why (a little mileage can be expected, maybe 2-3 miles).
Rob
Old 06-29-2005, 05:45 PM
Is eating.
True, thats why its always best that you do it yourself because if you do something YOU did it not just guy who could care less about your car.
Old 06-29-2005, 05:48 PM
J.Cutta's Avatar
Re: Help!?!
I believe I have found the cause it is a vaccum leak.. Its hard to explain on the drivers side under the car there is a little ball that connects to I dont know what, but it was removed. It broke off its mount in the accident but was still attached the shop took it off.
_______________
Old 06-29-2005, 05:51 PM
Is eating.
Well still you should fix the ICM as soon as possible.
Old 06-29-2005, 10:50 PM
89IROC&RS's Avatar
Re: Help!?!
i agree, fix the ICM, what was removed was the charcoal canister, which is a nessesary part of the emissions system, ask them why they didnt fix it.
