Old 06-29-2005, 02:59 PM
ovp0's Avatar
ovp0 ovp0 is offline
Question removing tree sap
What is the best way ro remove tree sap from the body and plastic parts without damaging the finish on either?
Old 06-29-2005, 03:55 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: removing tree sap
You local automotive store should have tar and sap remover for that.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-29-2005, 04:03 PM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
The clay detailing bars available from many companies also work very well for this. Mequires and Clay Magic make them and so do others. They all come with a spray lube that you use with it. Just follow the directions and you won't be disappointed.
Mark's Garage est. 1983
Old 06-29-2005, 04:11 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: removing tree sap
They are not meant to remove globs of sap.
Old 06-29-2005, 05:11 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
try rubbing compound
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 06-29-2005, 05:41 PM
blazee's Avatar
blazee blazee is offline
Problem?
I usually use rubbing alcohol and a cloth. Then I put a little wax over the spot, because the alcohol removes wax. I'm not sure if this is safe for the paint and clear coat, but I haven't had any problems.
Old 06-29-2005, 06:48 PM
BlazerLT's Avatar
AF -Advisor
http://www.bmwworld.com/repairs/detailing/tree_sap.htm
Old 06-30-2005, 08:28 AM
ovp0's Avatar
Thumbs up
Thanks for the replies.
Old 07-01-2005, 09:25 AM
Re: Re: Re: removing tree sap
Originally Posted by BlazerLT
They (detailing clay bars) are not meant to remove globs of sap.
Everytime I use them it works great for me. Here's a qoute from the web site posted by Blazer LT:
Old tar, tree sap, and paint over-spray can be easily removed with a miraculous new product called automotive clay. As you rub it across any type of surface (paint, glass, plastic, metal, rubber, vinyl) it instantly sticks-to and pulls-off all contamination that is stuck to the surface. Here's how to use an automotive clay bar:
  • To use the automotive clay, spray a water-based lubricant on a small area of your car and rub the bar back and forth with light to medium pressure. If the lubricant begins to dry, you'll need to spray more. Clay bars are fairly sticky, and they cannot be used dry.
  • After a few passes with the clay bar, rub your hand over the area to feel if the surface contamination was removed. Keep rubbing until all contamination bumps are gone. Finally, wipe the clay residue off with a soft terry cloth towel, and buff to a nice luster. Just like waxing, work in small areas.
  • Check the clay bar frequently for hard particles. When found, pick them off. Make it a habit to occasionally knead and reform the bar so that a fresh portion of the bar contacts your car's paint.
  • When you're finished claying your car, you should go over it with a pre-wax cleaner to finish cleaning the paint and restore essential oils. Then, protect your newly cleaned finish with one or more coats of rich Carnauba wax.
As far as removing "globs" of tree sap I can't say I ever had what I would consider globs and didn't see where ovp0 said he did either. The only product mentioned I would not recommend is traditional rubbing compound. That will cut into the clear coat.
Old 07-03-2005, 03:56 PM
BlazerLT's Avatar
AF -Advisor
One thing I found also good for removing stuff on paint is plain ole' window cleaner.
Old 12-07-2011, 06:55 AM
Automotian Automotian is offline
Try gasoline to remove tar and sap.... works great! Be sure to wash the area and re-wax after you are done to protect the clear coat or paint!
