Old 06-29-2005, 10:23 AM
GONZO9 GONZO9 is offline
Question Horns Dead!
Hey Forum! This Morning I Pressed Down On The Horn And Nothing Came Out . I Figured It Was The Fuse But Guess What Cant Find The Fuse...is There A Fuse For This ? I Checked My Fuse Panel On The Side Of The Dash Board And Didnt See Anything That Said Hron! I Have A 95 Silverado With A 350 5.7 L If This Helps ......thanks For Looking And If Ya Can Help....gonzo
Old 06-29-2005, 10:27 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
you might check under the hood see if there is a fuse there. or get your manual out and find what fuse controls the horn. or pull each fuse 1 by 1 till you find a blown one. another thing you might check is the conection on the horn it self they could be corroded or rusted. hope this helps
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 06-29-2005, 10:28 AM
if this doesnt help you might try the ck forum for the year of your truck, this forum is for the 99-05 trucks
Old 06-29-2005, 10:33 AM
Re: Horns Dead!
i looked under the hood and found 2 horns,on mounted behind the grill and one mounted just near the driver side head lights under the hood....i have a haynes manual that doesnt help me out .....thanks for the help
Old 06-29-2005, 11:25 AM
chuck16's Avatar
chuck16 chuck16 is offline
Re: Horns Dead!
Try hot wiring the horns to the battery directly just to confirm that the horns work. The other thing is that your contact in your steering column might not be making contact to the constant contact ring.
((Should I say Contact more???))
I had a 90 Blazer that the horn didn't work right turns out the constant contact ring behind the steering wheel was dirty and only had different contact points. Try holding your horn button down and turning the wheel to see if your horns go off.
Nothing worse than having a vehicle with no working horn.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
