ABS Brakes
Hello;
I have a 2001 - Grand Prix GT whereby over the past couple of mnths the "Traction"* is taking itself off randomly (more frequently in last couple wks) whereby the ABS then kicks-in. Usually the "Trac" button on the dash has to be pressed in order for the car to switch to ABS , otherwise what would be the cause - whereby it's doing this on it's own?... I had the brakes (pads+roter's) replaced last summer but had no problems, up until recently. Any suggestion's appreciated. Mancini ----
Re: ABS Brakes
i think there may be a short in the traction control switch or button.
I have a 2001 - Grand Prix GT whereby over the past couple of mnths the "Traction"* is taking itself off randomly (more frequently in last couple wks) whereby the ABS then kicks-in. Usually the "Trac" button on the dash has to be pressed in order for the car to switch to ABS , otherwise what would be the cause - whereby it's doing this on it's own?... I had the brakes (pads+roter's) replaced last summer but had no problems, up until recently. Any suggestion's appreciated. Mancini ---- [/quote]
Re: Re: ABS Brakes
I'd say it's the traction control sensor. But have you have it scanned yet? Before you start throwing money at it, have it scanned.
Re: ABS Brakes
Sounds like a bad ABS sensor in the hub bearing. Its a fairly common problem and will cause the symptoms you describe.
