Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-29-2005, 04:57 AM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
420a Going all out
The engine I have, decided to throw a control arm through the block. Anyway, I'm looking to go ahead and do some performance mods while I'm rebuilding. I need to know where I can find a good crate engine or at least the block. From the advice of scottsee and some of my friends I'm going to put my compression around 8.5 so I can run 18 psi. Any recommendations would be nice.
AF COMMUNITY GUIDELINES
Old 06-29-2005, 05:11 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: 420a Going all out
Originally Posted by fiberglasscivic
The engine I have decided to throw a control arm through the block.
Do you mean connecting rod?
well i would buy a used block since your rebuilding it anyways. no need to spend all the money on a crate motor and rebuild it. just go with well proven brands. i wouldnt ventuire out to far into ebay either for parts when your rebuilding a motor.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 06-30-2005, 12:03 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
A crate motor of what? A 420A block is the best you're putting in that engine bay, but you can build the motor for turbo if you like. Don't assume you'll run any psi... that comes later. Personally I'd take the opportunity to get a nice GST/GSX.
Old 06-30-2005, 07:17 AM
Re: Re: 420a Going all out
Yes, sorry, I don't know what I was thinking.
I didn't pay for this car and selling it would only get me about $300. Did you read my sig. I wasn't kidding. My car is in rough condition. I got it from a friend that was tired of putting money into upkeep. He threw the control arm through the block and said that was the last straw and signed the pink slip over to me. I pulled the motor and nothing from the bottom end is reusable. The head might be OK but I need to have it dye tested first. The paint job I don't know what the guy that painted it was thinking. It's the worst $200 paint job I've ever seen. They painted the poor thing canary yellow. I don't have a problem with yellow but when you can still find patches of the original color (green) around the door jambs the wing and the windows, something isn't right. It was missing the front bumper (blitz copycat body kit) and the back one was in rough enough condition that I took it off and threw it away. I figured while its apart and in such dire need of an overhaul then I would go all out. That's why I'm looking at doing the reverse lambo door conversion and squeezing as much whp out of a 420A as i can. That doesn't even include the fact that if i even considered doing a swap that i would have to get rid of a perfectly good tranny and clutch and then find a new one for the 4g63. I think my plate is full enough thanks.
Old 06-30-2005, 07:22 AM
Do you know where I can find a cheap used block because all of the places I've found are really pricy.
Old 06-30-2005, 09:19 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
eBay
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-02-2005, 02:59 PM
I don't trust ebay enough to put it on my car.
Old 07-02-2005, 11:30 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
He threw the control arm through the block and said that was the last straw..
LOL. you did it agian!! its a rod, not contol arm..
DSM geek
Old 07-07-2005, 08:16 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
www.car-part.com
95 Talon TSI AWD
97 Eclipse GST
Old 07-15-2005, 04:08 AM
Thank you guys so much for keeping me straight on that. Somethnig in my brain has linked the two as being the same thing. I've got to fix that.
