Old 06-29-2005, 03:16 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Quick Brake Question...
ok, i need to know what 3000GT's came with what size rotors...
i think i remember reading that the 3000GT VR4 came with a 12.5" rotor...did all of the 3000GT's come with this rotor, or just certain years or models???
i am doing some experimenting with my 300zx brake system to see if i cant get some more leverage and better heat dissipation. 11" rotors just arent going to cut it...
thanks in advance
ZedEx Crew Member #4
Old 06-29-2005, 08:48 PM
Hotshot8792 Hotshot8792 is offline
Re: Quick Brake Question...
thanks in advance
i've never actually measured the rotors, but i do know that the vr-4 and RT/TT rotors are much larger than the other cars. And definitely the brake calipers, which is why they often have clearance issures with their wheels, but the whole vr-4/rttt brake system is superior to the N/A's brake system in every way. Not sure what exactly your wanting, but your best bet is to check out their rotors first and see if thats what you are wanting.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-29-2005, 11:18 PM
Z Cars Fanatic
Re: Re: Quick Brake Question...
ok, thanks for the info.
does anyone know the size of the VR4 rotors??? did they change it at anytime???
i am pertty sure the VR4 came with a 12.5" rotor but i need to know which years so when i order the rotors i receive the right ones.
im thinking that the 99's came with 12.5" rotors but did any others?
Old 06-30-2005, 01:38 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
91-93 rotor are smaller than the 94-99, but I do not know the sizes.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 06-30-2005, 01:49 AM
Z Cars Fanatic
ok thank you...this helps a little more.
anyone feel free to add...upgrading brakes on the 3000gt must not be very popular.
Old 06-30-2005, 02:14 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
http://www.stealth316.com/2-brakeupgrade.htm
91-93 vr4/tt had 11.62in rotors on front
94-end vr4/tt has 12.36in rotors on front
not sure about the rear rotor year/size
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-30-2005, 03:21 PM
The only brake upgrades most people do is to the 2nd Gen VR4 brakes. Not many people have a need for bigger. Hell most aftermarket brakes are barely any bigger, so If you get good pads and rotors its way cheeper for basicly the same effect.
Also, rear rotors on the 91-93 are the same no matter NA or VR4
Old 06-30-2005, 08:36 PM
if the 2nd gens went any bigger on brakes, they wouldn't be able to buy any wheels to clear those calipers lol
Old 06-30-2005, 11:46 PM
Z Cars Fanatic
ahh...thanks a bunch, just the info i was looking for.
as for clearing wheels. my 300zx calipers are taller than the vr4 calipers and i could clear a 14" rotor with my 18" wheels. just a thought...but yeah, i always knew that the VR4 had a very good brake set-up to combat its weight. this is partly why im choosing the VR4 rotors to do my "mild" big brake kit.
Old 07-01-2005, 12:09 AM
Re: Re: Re: Quick Brake Question...
http://www.3sxperformance.com/brakes.asp
note the "bigger" brake upgrade, granted you need the stock 18" wheels.
Old 07-01-2005, 02:29 PM
Z Cars Fanatic
Re: Re: Re: Re: Quick Brake Question...
there you go...13.5" rotors. nice!!!
im sure if one did a little more research, you could find bigger and bigger rotors that come with the big brake kits.
