Old 06-29-2005, 12:25 AM
cowboyili cowboyili is offline
Cool camshaft position sensor
my check engine light is on and the reason im getting is code P0341 - camshaft position sensor. i have the 98 Grand Prix GTP supercharged 3.8. i bought the part for 30 bucks but im having trouble finding it. i have the chiltons manual but it covers so many cars that some parts arent even helpful. where can i find the CAMSHAFT POSITION SENSOR on my car?
thanks in advance
Old 06-29-2005, 08:33 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: camshaft position sensor
it's located in the timing cover, just slightly above and behind the harmoic balancer (at about 10 o'clock). It's held in place by one bolt.
Old 06-29-2005, 10:07 AM
BNaylor's Avatar
BNaylor BNaylor is offline
thanks in advance
Here's a pic from a GTP to help you out with the harmonic balancer removed. As the previous poster mentioned its around 10 - 11 o'clock. The opposing sensor at 2 o'clock is the crankshaft position sensor (CKPS). You'll have to pull the harmonic balancer and after that it will be obscured by a plastic cover which has to be removed next.
Also check the condition of the wiring, especially the electrical connector plugs to both sensors and clean with electrical contact cleaner after putting in the new camshaft sensor. Good luck!
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, TB spacer,
MSD 8.5mm wires, Autolite 104 Spark Plugs,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 06-30-2005, 07:39 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Try these two;
Old 06-30-2005, 08:27 AM
BNaylor's Avatar
Re: Re: camshaft position sensor
Originally Posted by kustomkid54
Try these two;
Nice Jim. A picture is worth a thousand words, however,.......????? That pic doesn't show the camshaft position sensor.
Are you putting that new service manual to good use? BTW - keep up the good work.
Timeslip 08/12/06
Old 01-14-2018, 12:24 PM
Anthony8point Anthony8point is offline
The camshaft senser is at the top left of the water pump
Old 01-14-2018, 12:42 PM
Tech II Tech II is offline
This is a 13 year old post....
